Hello all, this is something many of you may or may not know about so I thought I would put it up and see what people think.
Recently an engine was built by me and the bolt for the idler pulley on the timing belt snapped. This happened about 2000km in (I think). All my engines get new bolts there so it came as quite a surprise. The owner and I decided to investigate. I have never had a new bolt break in this way.
He flies aircraft and has contacts for testing bolts etc so we bought 10 8.8 high tensile M10 x 70 bolts and sent them to his guy for MPI (Magnetic Particle Inspection) testing.
7 out of the 10 failed the MPI due to surface irregularities that are at high risk of a crack starting in that area.
So we had three we could use on his engine. I decided to send the other 7 off to be treated to see if we can improve the statistics and then have them re-tested.
I'll let you all know the result once I have them
https://www.sau.com.au/forums/topic/290065-bolt/
Same thing happened to my engine, 500kms in.
New piston, valves, head and a new idler bolt later. Was rebuilt and has been going strong.
If you eventually get a new stronger replacement, i would be buying one off you in a second if i or anyone i knew was building an RB.
As the result of a snapped $15 bolt creates a whole word of heartache :(
And Daniel im sure you have done a few timing belts, but i think the tension has a part to play with these bolt failures also.
https://www.sau.com.au/forums/topic/290065-bolt/#findComment-4854482
Out of interest, was any other damage caused when this bolt snapped? Was it a bolt supplied by Nissan or otherwise?
yeah every valve touched. Decoro valves too.
I know what you mean NYTSKY but I can assure you overtension is not a problem.
I would have done 20 belts this year alone. Always set them a certain way and double check deflection after 4 rotations.
It was a genuine Nissan bolt and washer. The other 10 purchased are aftermarket bolts
I'm going to try cryogenic treating them first, then back in for MPI
https://www.sau.com.au/forums/topic/290065-bolt/#findComment-4855292
never heard of it, are those bolts being torqued up or by hand, Ive done many on rb engines and never felt the need to replace the bolt, i tension by hand with loctite using original bolt, Is sounding like the brand new replacement bolt isn't up to the original spec.
https://www.sau.com.au/forums/topic/290065-bolt/#findComment-4856150
Go and get an old idler bolt xrayed. You'll never put one back in, I gaurantee it!
the new bolt that snapped was a genuine nissan bolt made for the idler pulley specifically ??
yes it was.
https://www.sau.com.au/forums/topic/290065-bolt/#findComment-4857691
yes it was.
yes the new bolts are actually a Navara part number which is a little bit of a concern.
Edited by DiRTgarage
https://www.sau.com.au/forums/topic/290065-bolt/#findComment-4857708
Um couldn't you simply sue Nissan for the damages if you can prove, with xrays and whatnot, that it was their genuine bolt that snapped due to shoddy QC ?
Already considered that but it's not really in my best interest (or budget) to chase a large car dealership for around $2000
https://www.sau.com.au/forums/topic/290065-bolt/#findComment-4858446
small claims tribunal costs nothing .. I'm sure they'd pay up to avoid bad publicity if you had expert opinions (and xrays) that it was their bolt that failed under normal conditions.
1. It's probably like 3 - 4 days of my time which works out to be about $3k
2. It's not working under normal conditions considering its a RB26/30
3. They could just say I have to prove it wasn't my fault, which there is no way that I can other than going off the other gazillionty timing belts I have done without problems.
https://www.sau.com.au/forums/topic/290065-bolt/#findComment-4858492
+1 Get a higher grade. The extra safety factor in property class 12.9 or 10.9 bolts will help or you can try removing the surface irregularities by polishing
Property class 12.9 is 1200MPa UTS and 0.9x(1200)=1080MPa yield
Property class 10.9 is 1000MPa UTS and 0.9x(1000)=900MPa yield
as compared to
Property class 8.8 is 800MPa UTS and 0.8x(800)=640MPa yield
https://www.sau.com.au/forums/topic/290065-bolt/#findComment-4858695
  • 3 weeks later...
Anyone had this problem with the tensioner pulley stud? I just snapped mine! :thumbsup:
Luckily no engine damage though! :)
Yeah I had a guy come in with a noise once. Turns out the tensioner stud broke and the belt was pushing the bearing into the side of the lower cover. Lucky save that one was.
https://www.sau.com.au/forums/topic/290065-bolt/#findComment-4893249
Yeah... pretty much the same problem here. The car started making a horrible noise. Pulled off the timing covers to find heaps of slack on the tensioner side of the belt. So lucky not to skip any teeth!
I wonder if this is in any way related to power levels ? ie. has anyone had either the factory tensioner or idler pulley bolts snap out of the blue on a mildly modified car ie 200-270kw?
Mine would fall in this category.
https://www.sau.com.au/forums/topic/290065-bolt/#findComment-4893647
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
