Hello all, this is something many of you may or may not know about so I thought I would put it up and see what people think.
Recently an engine was built by me and the bolt for the idler pulley on the timing belt snapped. This happened about 2000km in (I think). All my engines get new bolts there so it came as quite a surprise. The owner and I decided to investigate. I have never had a new bolt break in this way.
He flies aircraft and has contacts for testing bolts etc so we bought 10 8.8 high tensile M10 x 70 bolts and sent them to his guy for MPI (Magnetic Particle Inspection) testing.
7 out of the 10 failed the MPI due to surface irregularities that are at high risk of a crack starting in that area.
So we had three we could use on his engine. I decided to send the other 7 off to be treated to see if we can improve the statistics and then have them re-tested.
I'll let you all know the result once I have them
https://www.sau.com.au/forums/topic/290065-bolt/
Same thing happened to my engine, 500kms in.
New piston, valves, head and a new idler bolt later. Was rebuilt and has been going strong.
If you eventually get a new stronger replacement, i would be buying one off you in a second if i or anyone i knew was building an RB.
As the result of a snapped $15 bolt creates a whole word of heartache :(
And Daniel im sure you have done a few timing belts, but i think the tension has a part to play with these bolt failures also.
https://www.sau.com.au/forums/topic/290065-bolt/#findComment-4854482
Out of interest, was any other damage caused when this bolt snapped? Was it a bolt supplied by Nissan or otherwise?
yeah every valve touched. Decoro valves too.
I know what you mean NYTSKY but I can assure you overtension is not a problem.
I would have done 20 belts this year alone. Always set them a certain way and double check deflection after 4 rotations.
It was a genuine Nissan bolt and washer. The other 10 purchased are aftermarket bolts
I'm going to try cryogenic treating them first, then back in for MPI
https://www.sau.com.au/forums/topic/290065-bolt/#findComment-4855292
never heard of it, are those bolts being torqued up or by hand, Ive done many on rb engines and never felt the need to replace the bolt, i tension by hand with loctite using original bolt, Is sounding like the brand new replacement bolt isn't up to the original spec.
https://www.sau.com.au/forums/topic/290065-bolt/#findComment-4856150
Go and get an old idler bolt xrayed. You'll never put one back in, I gaurantee it!
the new bolt that snapped was a genuine nissan bolt made for the idler pulley specifically ??
yes it was.
https://www.sau.com.au/forums/topic/290065-bolt/#findComment-4857691
yes it was.
yes the new bolts are actually a Navara part number which is a little bit of a concern.
Edited by DiRTgarage
https://www.sau.com.au/forums/topic/290065-bolt/#findComment-4857708
Um couldn't you simply sue Nissan for the damages if you can prove, with xrays and whatnot, that it was their genuine bolt that snapped due to shoddy QC ?
Already considered that but it's not really in my best interest (or budget) to chase a large car dealership for around $2000
https://www.sau.com.au/forums/topic/290065-bolt/#findComment-4858446
small claims tribunal costs nothing .. I'm sure they'd pay up to avoid bad publicity if you had expert opinions (and xrays) that it was their bolt that failed under normal conditions.
1. It's probably like 3 - 4 days of my time which works out to be about $3k
2. It's not working under normal conditions considering its a RB26/30
3. They could just say I have to prove it wasn't my fault, which there is no way that I can other than going off the other gazillionty timing belts I have done without problems.
https://www.sau.com.au/forums/topic/290065-bolt/#findComment-4858492
+1 Get a higher grade. The extra safety factor in property class 12.9 or 10.9 bolts will help or you can try removing the surface irregularities by polishing
Property class 12.9 is 1200MPa UTS and 0.9x(1200)=1080MPa yield
Property class 10.9 is 1000MPa UTS and 0.9x(1000)=900MPa yield
as compared to
Property class 8.8 is 800MPa UTS and 0.8x(800)=640MPa yield
https://www.sau.com.au/forums/topic/290065-bolt/#findComment-4858695
  • 3 weeks later...
Anyone had this problem with the tensioner pulley stud? I just snapped mine! :thumbsup:
Luckily no engine damage though! :)
Yeah I had a guy come in with a noise once. Turns out the tensioner stud broke and the belt was pushing the bearing into the side of the lower cover. Lucky save that one was.
https://www.sau.com.au/forums/topic/290065-bolt/#findComment-4893249
Yeah... pretty much the same problem here. The car started making a horrible noise. Pulled off the timing covers to find heaps of slack on the tensioner side of the belt. So lucky not to skip any teeth!
I wonder if this is in any way related to power levels ? ie. has anyone had either the factory tensioner or idler pulley bolts snap out of the blue on a mildly modified car ie 200-270kw?
Mine would fall in this category.
https://www.sau.com.au/forums/topic/290065-bolt/#findComment-4893647
    • That’s a beautiful setup Tao, Have u done any development with the new Turbosmart 40mm electronic straight gate, especially in this G30 configuration?
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
