If you are going to do your timing belt, then make sure you replace the idler bolt. It has not really got anything to do with power levels. It only has to do with the bolt already having cracks. If in doubt, take your old bolt to an engineer for a crack test or xray and you will find it is fubar.
We are using 10.9 grade bolts as 12.9 is usually a cap head and I have seen these foul on the lower cover as they sit too proud.
A breakage of a new geniune bolt is not a common thing so don't everyone start getting paranoid, out of the approx 80 timing belts I have done on skylines, this is the only new one to have broken. This is why I am taking on the experiment because we have the resources at our disposal and it will also help to clarify some cryotreating questions we have at the same time.
Hopefully it goes in for treatment this weekend. We are waiting in them having enough other jobs to warrant such a small one. We have also found that no bolt manufacturers will give any gaurantee on a bolt for any reason, so if a new one breaks, you are on your own.
https://www.sau.com.au/forums/topic/290065-bolt/page/2/#findComment-4893722
Does anyone know the bolt dimesions to see if this could be cross referenced to any arp stuff..like an L19 bolt (260,000 psi tensile strength which is 1792 Mpa).
Overkill yes..but for peace of mind i wouldnt mind the extra few $$.
https://www.sau.com.au/forums/topic/290065-bolt/page/2/#findComment-4894381
we looked at upgrading to a better/harder material bolt but were a little worried the stronger bolt without any sort of flex may actually cause the cast iron block to fatigue and possibly crack the casting.
new genuine bolts and studs are the go in my opinion.
https://www.sau.com.au/forums/topic/290065-bolt/page/2/#findComment-4894667
I agree with Paul. I have done many timeing belts on GTR's of all power levels useing new factory bolts and have never had a problem. I would say that the bolt breaking in this case is just pure bad luck. And as Dan stated this is not a common problem so lets not all get paranoid.
https://www.sau.com.au/forums/topic/290065-bolt/page/2/#findComment-4894826
  • 3 months later...
How are the grade 10.9 bolts going? You haven't found them coming loose at that tension? or do you put some loctite on them?
Also so I can source the bolt before disassembly, is the M10 bolt a 1.5mm pitch?
https://www.sau.com.au/forums/topic/290065-bolt/page/2/#findComment-5091635
Come on Dan I know of another one that caused a great deal of shite because I bought a turbo off the guy and because I am a friend he dicked me around no end. If I remember rightly an investigation was carried out and the bolt was found to be faulty.
A button head cap bolt is lower profile than a normal bolt and wont fowl.
https://www.sau.com.au/forums/topic/290065-bolt/page/2/#findComment-5098189
Not sure what that means Terry but no, it was not a new bolt.
I was instructed by that customer to not replace the bearings...only the belt. The idler bolt was never touched and broke 3000km later. That was a factory bolt and yes it was tested and found to have multiple fractures throughout.
I have all of these grade 8.8 bolts here ready to send off for MPI, just waiting for the oportunity.
https://www.sau.com.au/forums/topic/290065-bolt/page/2/#findComment-5099304
You need an M10 x 1.5 x 70mm bolt.
As stated above, no problems with the grade 10 bolts being used. Cap heads sit proud and can touch the timing cover so stay away from the grade 12 bolts if you can. There is no need to go that high anyway.
Make sure the washer goes back under them
https://www.sau.com.au/forums/topic/290065-bolt/page/2/#findComment-5099614
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
