hi guys,
afew days ago i tried to change my led for my glovebox and the next thing i know my dash lights, rear tail lights, gauge lights, a/c lights, parker lights, glovebox lights are not working
any idea what happened ? did i blow a fuse? if so where and which one do i change it ? i know r33s is located at the driver side but i have no idea for r34s
p.s. my roof light, map lights and hid lights are working fine as well as my brake lights.
https://www.sau.com.au/forums/topic/290097-r34-no-lights/
with my R34, i thought it woulda been under the steering wheel like my r33, but the R34 had a little glove box under there instead, it ended up being in the engine bay right behind the battery..check that out
https://www.sau.com.au/forums/topic/290097-r34-no-lights/#findComment-4855329
Was out driving one night when all my lights went out on the freeway. Took the fuse from the horn under bonnet next to battery and swapped it over with the headlights fuse (to see if it was the fuse to begin with) and it fixed my problem. next day bought another fuse for my horn. Just curious teo what colour led did u try put in ur glove box? but yeh man turn lights off next time huh lol
Edited by 1R34SON
https://www.sau.com.au/forums/topic/290097-r34-no-lights/#findComment-4856996
yes most of the light fuses are behind the battery in the engine bay but they do also have a fuse box in the cabin next to the accelerater pedal behind the kick panel. if you put your head down there you will see it. i could be wrong but the interior lights fuse could be on the inside fuse box as i can see them listed on the engine bay coveas i have 1 translated in english sitting on my computer desk.
https://www.sau.com.au/forums/topic/290097-r34-no-lights/#findComment-4857387
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
