hi guys,
afew days ago i tried to change my led for my glovebox and the next thing i know my dash lights, rear tail lights, gauge lights, a/c lights, parker lights, glovebox lights are not working
any idea what happened ? did i blow a fuse? if so where and which one do i change it ? i know r33s is located at the driver side but i have no idea for r34s
p.s. my roof light, map lights and hid lights are working fine as well as my brake lights.
https://www.sau.com.au/forums/topic/290097-r34-no-lights/
with my R34, i thought it woulda been under the steering wheel like my r33, but the R34 had a little glove box under there instead, it ended up being in the engine bay right behind the battery..check that out
https://www.sau.com.au/forums/topic/290097-r34-no-lights/#findComment-4855329
Was out driving one night when all my lights went out on the freeway. Took the fuse from the horn under bonnet next to battery and swapped it over with the headlights fuse (to see if it was the fuse to begin with) and it fixed my problem. next day bought another fuse for my horn. Just curious teo what colour led did u try put in ur glove box? but yeh man turn lights off next time huh lol
Edited by 1R34SON
https://www.sau.com.au/forums/topic/290097-r34-no-lights/#findComment-4856996
yes most of the light fuses are behind the battery in the engine bay but they do also have a fuse box in the cabin next to the accelerater pedal behind the kick panel. if you put your head down there you will see it. i could be wrong but the interior lights fuse could be on the inside fuse box as i can see them listed on the engine bay coveas i have 1 translated in english sitting on my computer desk.
https://www.sau.com.au/forums/topic/290097-r34-no-lights/#findComment-4857387
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
