so the story goes.... i fitted my new cefiro shell with the old RB20 from my old cefiro.
all went smoothly engine fired up almost instantly. had a few teething issues as you would expect, started and stopped it numerous times without trouble. whilst i had the engine running it just died. the fuel light was on so i assumed it was out of gas.
had a few other things to do so hasnt been started for approx 6 weeks..... fueled it up.... now it wont start just gives massive bangs through the exhaust.
*put brand new plugs in
*fitted different pump
*fuel is running the correct way
*battery is good to go
how can i tell if the CAS or ignitor is stuffed without a multimeter??
when i plug in the CAS you can hear the fuel pump prime, if that helps at all
any help is appreciated.
cheers.
https://www.sau.com.au/forums/topic/290109-rb20-wont-start/
Remove the CAS and spin the shaft by hand while it it plugged into the loom and the ignition key is on, check that the injectors and coils are firing. It should start with the AFM disconnected (will run in limp mode), then turn it off and reconnect the AFM, if it doesn't start then possibly the AFM is rooted.
Have you tried checking ECU error codes?
https://www.sau.com.au/forums/topic/290109-rb20-wont-start/#findComment-4857370
error codes came back as 55 so no answers there. i tryed to check for spark.. pulled no 1 plug out left it on the coilpack and let it rest on the cam cover, cranked it and got nothing, wasnt sure about the surface so tryed fuel rail feed also got no spark... possibly a ignitior issue or could the CAS cause no spark ??
https://www.sau.com.au/forums/topic/290109-rb20-wont-start/#findComment-4857438
luke it would seem you were bang on...
put another ignitor in this morning, still no change. messed around with a few other things incuding leaving the AFM unplugged. motor tentatively started. was then i realised AFM wasnt plugged in. plugged it in and motor was a little smother but would still cutout a little when revving. motor then dyed after about 5mins of running. messed around with CAS not really thinking about the AFM but couldnt get it started again... then unplugged the AFM and it once again tentatively started... plugged in the AFM and the motor instantly died. therefore im guessing once the AFM warms up it dies.... plus the fact the motor wont even start with it plugged in.
https://www.sau.com.au/forums/topic/290109-rb20-wont-start/#findComment-4857891
If it starts without the AFM and not with it then I would say the AFM is stuffed. The engine should run perfectly normal (maybe a high idle) with the AFM unplugged it will just be limited to 2500rpm.
Try pulling the CAS out and turning it by hand. If your CAS is stuffed you won't get any spark or fuel. If it's good you should hear the injectors clicking and see the spark from the coils (just pull the coils and rest them in the valley between the cam covers, they should have enough power to arc out to the cam covers).
Also inspect the half moon shaped key on the shaft of the CAS and on the end of the exhaust cam. If either of them are flogged out then the CAS will be sloppy on the shaft and your timing will be all over the place.
Also, have you tried adjusting the CAS while it is running?
https://www.sau.com.au/forums/topic/290109-rb20-wont-start/#findComment-4858158
injectors are ticking fine but cant see any spark... motor is a lil on the rough side with the AFM unplugged. havent been able to get any spark from no1 coil but am yet to try any of the others. but it was on all 6 cylinders when it was running with everything plugged in.
hole moon looks to be in good condition.
havent really had it running well enough to play around with the CAS.
bear in mind the AFM has been sitting around with no protection for the past 6 months.
EDIT: ok can finally confirm spark, but CAS seems to have alot of play/or just very sloopy.
Edited by esky_mad
https://www.sau.com.au/forums/topic/290109-rb20-wont-start/#findComment-4858245
ok i cant seem to edit my post previous posts... anyway it seems im back at square one.
can confirm im defnitely getting spark from all coilpacks, all injectors are ticking, tryed another CAS (from a CA but coils and injectors still tick and fire) Error code 12 flashes when the AFM is plugged in, but even without it pluuged in it wont fire. havent made any wholesale changes since it came out of the old car which is why i find it strange its being so difficult to start.
whilst trying to start it it turns over fine but then slows right down as if the battery is dying but then picks up again then slows down.. will crank fine for ages then slow down again etc etc... dodgy battery ?? shouldnt it still fire whilst its cranking over ok ? i would assume it shouldnt have any affect anyway for it to die everytime it does(did) start, unless the alternator is coincidently dead aswell.
ive tryed the CAS is different positions but with no luck.......... serioulsy sick of this car!!
https://www.sau.com.au/forums/topic/290109-rb20-wont-start/#findComment-4859737
ok im one of those people that cant let something go until its fixed or i at least no whats wrong with it...
did some more poking around and when the fuel line from the engine side of the filter is off this is what happens...
turn on the igniton.. fuel pump primes.. fuel pours out of the filter..wait.. crank the engine.. no fuel from the filter..
crank the engine all in one turn(no waiting for the pump to prime).. no fuel comes out.. i dont no much about fuel pumps, or fuel systems but surely it needs constant fuel to start, is it a result of poor voltage to the pump when cranking ??
obviously being an RB20 nowhere cares to much about my issues but some advice would be nice.
https://www.sau.com.au/forums/topic/290109-rb20-wont-start/#findComment-4859808
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
    • from an old insurance company i was with (Budget Direct) I had someone roll back into me at the lights got them to pull over. Got a picture of thier licence with address, had a dash cam video and, thier phone number. But only had 3rd party on the shitbox i was driving. insurance did nothing, cops wouldn't do anything due to the value of the damage (under $3000) so i just had to suck it up and go to U Pull It.
    • Small Update on the Exhaust Situation A 200-cell cat was a bit too expensive for now, so I had the exhaust shop fabricate a new exhaust from the cat to the rear and an exhaust tip. I went this route to avoid cutting into the original exhaust and keep it intact. It’s essentially straight-piped, and the sound is noticeably different. The exhaust tip came with a silencer, so if it gets too loud, I can easily install it to tone things down slightly. Right now, the car bangs and pops like crazy -- which I personally love. In the future, I might add a resonator or a 200-cell cat, as niZmO_Man suggested, but for now, I’m really happy with how it turned out.
    • And that's a massive problem, because deadshits will deadshit and give you false details. At least in these days of mobile cameraphones, it is trivial to take photos of any ID they are carrying at the same time as the 300 photo extensive documentation of the state of the vehicles that I recommend even for minor incidents. And you get photos of the person's face, any visible tatoos, etc etc, while you're at it. Then you try to avoid mentioning that you're fully capable of making explosives of various power levels and will wreck their shit if you are forced to hunt them down.
