That too, I set all FPS games to hard on the first go now, and the last 10 Ive bought I've soared through with very little repetition, but even playing older games seem longer even when you're flying through them.
Call of Duty: Modern Warfare 2 must have been..literally 3-4 hours at the most, it was f**kin' epic but very short.
For me, I don't like short games. The COD series (well MW1 and MW2) are extermelly short for my liking. I like a nice decent game with nice amount of time...I'm currently playing Borderlands and Assassin's Creed 2 and liking it so far.
But for me, If I sit down and start playing Emprie Total War or Football Manager...say goodbye to at least 4-5 hours
The problem is, once a company has been there done that, they have to try and come up with something new. As we adapt to the game styles, we can beat games quicker than before. Now that isn't to say the game companys haven't been getting lazy.
A perfect example is Duke Nukem. A game that could have been great if they released it when they were using the Quake 2 engine. They had the storyline, and most of it done, but then worried that the engine wasn't the way to go because it wasn't the latest and greatest. Look where they are now.
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
