Hey guys,
I recently got my SAFC II installed & tuned for my auto R33 GTS-T with the following support mods:
-3" turbo back exhaust with high flow CAT
-Apexi POD
-R34 GTT SMIC
-Turbosmart boost controller set at 10PSI
Car made ~240rwhp
On the way back yesterday & driving to uni today I noticed that the auto box's "shift points" have moved lower compared to b4 & its behavior have changed compared to b4.
B4 the "min speed" at which gear changes occur were at ~25, 50 & 70km/h, now the gear changes will happen at 20, 40 & 60km/h & the box also seems to be much "willing" to move up to overdrive as soon as possible compared to b4.
For example, before hand, as long as I apply a constant throttle (even if its a small one) the car will hold onto 2nd gear until 70km/h, to get it to change at the "min speed" of 50km/h I need to reach 50km/h, back off the throttle & let it change. I have to do the same thing for it to go from 3rd to overdrive.
But now, if I still apply a small constant throttle, it will change from 1st to 2nd to 3rd to OD all by itself without me having to do any of the above (lifting off throttle to let it change).
Also the speed at which the gear changes seem to have being moved down lower, as now gear changes occur at 20, 40 & 60 instead of the old 25, '50' & '70'.
As a result, b4 if I were driving at 60km/h the car would stay in 3rd gear at ~2500rpm, but now it would change into OD ~<2000rpm.
Also the gearbox also seem to be much more sensitive to throttle & load compared to b4 & will happily drop down gears compared to b4, where it would just act lazy & stay in the same gear unless I'm really flooring it.
Finally the gear changes seem to be faster compared to b4; it like to hang there for a sec or so b4 changing but now its just jumping through them at rapid rate.
Basically I would like to know is how is this even possible? Can a SAFC alter the gear box logic? My understanding was the all it does is change fuel mixtures at different rpm points to avoid the car running rich due to the extra boost & stock ECU. Or is this caused by something else?
I got the SMIC & boost controller installed at the same time as the SAFC, but I doubt they got anything to do with the change of behavior of the auto box.
Any info would be appreciated
Cheers.
https://www.sau.com.au/forums/topic/290134-safc-2-auto-gear-box/
Sounds like before it was shit and now it is working properly. The shop who tuned it probably noticed it was shit and then noticed the oil level in the biz was low so topped it up.
Have you tried contacting the shop who tuned it?
Possibly with the increased torque you are getting the auto will tend to upshift earlier.
Does the car feel sluggish/flatspot in anyway during the early upshifts?
Having upshift earlier with no side effects is not such a bad thing you save a little on fuel.
LOL, this was one of the idea that came to mind while I was looking at the subject, compared to b4 the box does indeed feels & act like all the other auto box cars I have driven (91 VN commodore & 02 Camry) in that it doesn't hold onto each gear for a long time unless I'm flooring it or have power mode on.
Haven't contacted the shop yet, might do that on SAT, damm too much uni work going on.
Maybe they cut the TPS wire (the one on the plug the transmission uses) instead of splicing into it.
I'm guessing thats a bad thing? Sorry don't really know much about all the electronic stuff.
I didn't notice any sluggish/flatspot during the shifts, the gear shifts are actually better than before, before, the gear change from 1st to 2nd were like a big 'jerk', & now the 1st gear change is more like a soft 'click' simlilar with the other gear changes. The gear changes are still not as smooth as the 02 Camry, but I take that is due to the old condition of the auto box.
Seems all good so far, the only thing I don't like atm is that, since it will change into final gear at 60km/h & now its much more sensitive to throttle it will happliy downshift to 3rd if my foot was even slightly down too much on the gas & go into 4th again when I ease of the throttle.
Atm I'm getting around this problem by just turning Overdrive off on normal roads & only turning it on, on roads with speed limit of 70km/h or higher.
Lastly its kinda hard to maintain the speed limit with this increase in power, torque & throttle response. I need to work on upgrading my regular granny driving style to super granny style to get it under control. :thumbsup:
  • 3 weeks later...
Happy to report that my fuel usage went down from ~13.5l/100km down to the 11s range :)
Its now on par with my mum's Camry but with much more P-O-W-E-R!!! <screams out in Jermy Clarkson tone>
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
