try this dude
http://www.jappartsspecialist.com
i just order my S15 power fc brand new around 1000AUD
and i just search the price from here, they do have the similar price like negun and jappartspecialist, but seems japparts sells lots of stuff in ebay and the feedback are excellent...
anyway just my personal suggestions, since i already brough a few things from them.
Lachlan, I have dealt with both, but only purchased from Greenline.
Greenline have to get parts from the manufacturer, and if they are available, they are pretty quick, ie 1 week. the longest Ihave had to wait is 3 weeks. you can ask about availability when you e-mail them.
Greenline were very helpful with product information, and even researched parts without my asking - point in note, I asked for a price for a Trust type R BOV, and they new I had a GTSt, they e-mailed back with the cost but also a warning that the bov is for GTR. I found them very helpful, good presales and aftersales service.
Nengun, I wanted some info on second hand parts. He took some time replying to my e-mail, but didnt answer all my questions (about power fc pro), so I resent. He could not answer my questions, nor direct me to where I could find out info on the product, his replies were very short and what I consider abrupt. He gave me the impression that he didnt have much time to spend with customer service. so I have been spending my money elsewhere.
Just my experiences, and the opinions expressed are my own. I know some people have had good results with Nengun, and I am sure if you knew what you wanted and just order from him, the whole process would be alot quicker and easier than if you require product info.
Just gotta throw in here, have a look at www.fvej.co.jp (or www.fvej.com) there is an expat aussie working for them, he has got me the best deal on second hand parts EVER, 40mm HKS wastegate second hand in near new condition for $290 delivered is one example. Definately worth a try - he doesnt get bargains all the time, but he has second hand (and new) suppliers all over Japan, and does do some killer deals - did I ever tell you how much my new HKS 3037 turbo was from him?
Thanks all.
Enrico, nothing specific just yet.
Steve, thanks for the info, and I pretty much agree with what you said re knowledge and service. Thanks for the other link and yes, Greg did tell me how much you paid and it was sweet FA!
Anyone else with any experiences with both these suppliers?
I emailed both Greenline and Nengun on the same day for quotes on the same part. Greenline responded within a couple of hours so I deposited the money and they shipped my order straight away.
I only received an email response from Nengun on the day my parts arrived from Greenline, that being about 2 weeks. Jason was really helpful so I'd recommend them :P
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
