with a v-spec gtr33 you pull the fuse out in the boot and the drive-shaft for the transfer diff, with a 32gtr and 33gtr non v-spec just the fuse comes out. you will see when you put the car on the dyno and start rolling the HICAS light will come on and then you know its working. dont trust hks split tourqe controlers cause the car will still grap on the dyno.
  • 3 weeks later...
I have now had a chance to add to this topic. Due to a recent skidpan day.
With a R33 GTR (non V-Spec) you can simply pull the fuse in the boot located second from the middle in the small fuse box to give yourself 100% RWD power.
However on a GTR V-Spec as mine is. Pulling the fuse labeled 4WD/LSD also causes the LSD to become inactive because of the hydraulic pump supplying pressure to both the 4WD transfer clutch and LSD clutch.
Therefore making it useless for dirft and skidpan days.
So i'm still searching for the solution without removing front shaft or spending $$ on HKS splitter crap. Plus removing the fluid from the pump is going to have the same effect on the active v-spec LSD. right? Neither will work. This option is good for ppl who just wanna use a RWD dyno, but no good for a wanna be drifter like myself.
Any comments ??
Ive just been out under my car and found that it wouldn't be that hard to clamp or block that line supplying fluid to the transfer case. Any 1 done this before?
Also there are two seperate electric supply plugs for the pump. any1 know about these?
What happens if you clamp the line though? The pump will still try to pump the fluid to the transfer case, but won't be able to....
Surely that can't be good for the ATESSA pump?
    • And also there were for sale scams and the like. For sale posts need piccies, and not having piccies makes it harder to do a driveby scam.
    • And I forgot to add my *** footnote to the above post, which was that the pipework mods would be even more significant than what had to be done for the highflow. So just add that onto the list. Pipework mods are no killer, just made the tasklist longer at a time when extra tasks were not welcome.
    • I mean he could post them to imgur or the like and create a link. But yeah, spam bots absolutely will post pictures in their first posts.
    • Ah ok, reason I asked was for the sake of not having to upgrade everything if the turbo couldn't be capped.
    • pffft! My alignments are starting to take 3-4 weeks each. Bugger overnight - that would be a dream! Overnight is when I leave it on stands with the rear suspension in pieces, hoping I can remember where I was at when I come back to it. I have to set the car up on a level surface so I can get decent camber measurements, then try to set the RUCAs to the right length to get that right. Then I have to put the car somewhere else where I have enough room to set up the bumpsteer gauge (laser, paper, mirror), so I can dial out that. Then I need to go measure camber again because changing the tension arm length affects that also. Then I need to measure toe, and I can't do that to my own satisfaction at home, so I have to put it on an actual aligner. Then I have to go back and fix the camber again, and if that took more than a half a turn, decide if I want to set up the bumpsteer measurements again. I previously had the bumpsteer almost completely banished and then I started changing things again! And that's only the rear end. Not even gotten to talking about the front yet. And this has been going on in the context of me discovering a seized bolt in the LHR FUCA bush at the upright, hence needing total disassembly to replace that bush and the others that were not far away from the same outcome, replacing sphericals in the front end and making a mistake that resulted in needing to do it again, which is only half done right now. It's a selfmade nightmare. Only have self to blame, etc etc. But regardless, I am so complelely unable to utilise the services of a normal wheel aligner that I have no choice. I haven't found a shop in my city that does "race" alignments - and by that I don't mean I want my car to be set up for racing, but the set of adjustments that I have available and that need to be used to do the alignment are the same as you'd find on a race car. I haven't looked everywhere, but there doesn't appear to be the equivalent of the motorsport focused shops that are present in Sydney and Melbourne. And such an alignment would cost $300, and you only want to do it once in a while, and you don't want to find out that you have to replace bushes and bearings and such while you are spending that $300 so you have to come back and spend it again a week later. So I stay living in my self made nightmare for the moment.
