Parked my car at work this morning and it got slightly nicked at the rear by a mates car. :) Not so bad but still..
I managed to get rid of most of the scratches, but obviously it needs a pro job for repairing the dent.
Can anyone recommend a good place in perth for that?
I got a quote for $700 at a smash repair shop in welshpool. But i don't know if i can trust these guys.
here's some pics. Not really visible but it's there :)
Bad luck dude I feel ur pain, lucky it was a accident with ur mate and not some random toss
I know, thank god for that.Felt awkward though, Poor bastard's saving up for his wedding next month as well.
Try Dent Craft 1st.
http://www.dentcraft.com.au/
If they can't fix it then:
Advantage Panel & Paint
Insurance & private work, performance cars, prestige cars. Osborne Park location. Quality & professional service.
40 Howe St
Osborne Park
Ph:(08) 9244 2665
or
McCarthy Panel & Paint
122 Gugeri St
Claremont
WA, 6010
Australia
Ph:(08) 9384 9400
Edited by mosoto
Try Dent Craft 1st.
40 Howe St
Osborne Park
Ph:(08) 9244 2665
or
122 Gugeri St
Claremont
WA, 6010
Australia
Ph:(08) 9384 9400
Thanks mate, but i'd rather stick to south of the river workshops for now. Should've mentioned that before.
I gave Dentcraft a go, but they can't repair it.
Anyways i got a quote for from $440 including respray for $440 AutoRepaint Smash Repair at Welshpool.
Has anyone been there?
The shop on Bannister Road is pretty good. I had the wifes silver M3 fixed there and can't complain, did a good matchup and silver is a tough colour to match on plastics. I'll get the name when I get home.
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
