The Alford GTR will be competing in Support of the V8's in the Australian GT series
http://www.australiangt.com.au/_assets/ENT...%20BATHURST.pdf
Should be a great class battle between the Z06, GTR and Exige. Last time At EC the Exige came out on top
My money will be on a clean sweep by Wall in the Cup S (but then again i am biased towards this team).
However with the amount of restriction on the 997 the lambo's will be strong. Viper will be unstoppable down the straights and the Aston shouldn't be too slow either so should be a good weekend of racing .
Better than the taxi's at least
Oh also forgot races will be televised :)
Edited by Whiplash
https://www.sau.com.au/forums/topic/290246-gtr-at-bathurst/
Seen the exige up close quite recently, real nice car. I know the Chief Engineer. Watch out for it, they have done something special to it.
https://www.sau.com.au/forums/topic/290246-gtr-at-bathurst/#findComment-4857382
Having both R35 and highly moded Exige (240R spec) in my Garage...
I can't see the Exige winning over an R35 in the Prod Class on anything but the smallest of tracks ....as the Exige just does not have the legs.....
But hey.......all it takes is some talented driver and one Exige getting trashed to an inch of implosion.
https://www.sau.com.au/forums/topic/290246-gtr-at-bathurst/#findComment-4859106
wonder what sort of handicaps each competitor runs?
Its a case by case situation.
The Wall Cup S has everything under the sun short of having to tow a caravan to slow it down. To a point where it was dangerous (and outside FIA regs at the Clipsal)
So the more success = Greater restrictions on the car.
https://www.sau.com.au/forums/topic/290246-gtr-at-bathurst/#findComment-4859290
My Bad, I misunderstood the classes. I didn't read whiplash's original post properly about the production class. :ermm:
The car I am talking about is the Elise GT3 car in the championship not production class.
Go the GTR in production class :rant:
Edited by Deano45
https://www.sau.com.au/forums/topic/290246-gtr-at-bathurst/#findComment-4869600
Aston Martin Flying around the Track today 2 Seconds over the 911 contingent and a new GT lap record
Hmm GTR ungunned by the lotus and the Vette
http://www.natsoft.com.au/cgi-bin/results....10/2009.MOUN.P1
http://www.natsoft.com.au/cgi-bin/results....10/2009.MOUN.P5
Production Class
Z06 Corvette 2.22.1225
Exige S 2.22.8571
Nissan GTR 2.26.4661
https://www.sau.com.au/forums/topic/290246-gtr-at-bathurst/#findComment-4869668
Production Class
Exige S 2.22.8571
Them is some pretty hopeless lap times for an R35. Was it raining?
You will remember that Luff ran a Bathurst lap time in a bog stock Aussie R35, wearing Bridgestones,
on a damp track, requiring him to brake and lose 50km/h before entering the chase.
He still ran a 2:25.
What gives? I would expected better from a stock GT-R, let alone a race prepped one.
https://www.sau.com.au/forums/topic/290246-gtr-at-bathurst/#findComment-4869787
No nissan pulled out of being the safety car.
V8 supercar want the GTR to be painted in XXXX colours and nissan refused to have the "safety" car linked with alcohol. Fair enough i say, so Nissan took the car back and now AUDI supply the safety car
https://www.sau.com.au/forums/topic/290246-gtr-at-bathurst/#findComment-4872197
Ahh wat a joke.
Like the exec's dont have a drink or 3.
https://www.sau.com.au/forums/topic/290246-gtr-at-bathurst/#findComment-4872304
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
