hey people , im currently doin a few minor mods to my 33 and i was thinking of removing the bov so that i get massive turbo flutter from my brand new t04e that im puttin on it and i was wonderin if , by taking off the bov will damage my new turbo? .
cheers shawne ;)
https://www.sau.com.au/forums/topic/290289-bov-or-turbo-flutter/
  • Replies 41
Posted Images
compression surge is not healthy unless u live in vic and drive a VL ? and go to bell st maccers
stock plumb back bov ftw!
LOLLz
but yeh,,stok bov's are shyt,,get a stocky r33 gtr one
You may wind up stalling it everytime you pull up at a roundabout or lights... but go for it.. i thought it was awesome fun when i first tried it... and refitting it costs nothing...
dunno if it will root ur turbo though after prolonged use...
I've found a stock BOV with the internal bleed hole made 50% smaller gives a great comprimise between sound and surge. Blocking it completely, surges too much in higher gears on the highway and makes tons of noise. Also try getting a pod, makes much more sound.
cheers shawne :)
Yes it will after a while and you will get increased lag.
Correct, but if you have a bov set to loose then it can also cause stalling. If you have a bov and tighten the spring in it then it will only open on high pressure, so you can get flutter with only a small amount of boost. savvy?
bro, jus get an fmic. after i put one on my car it made a flutter on high boost..nothin special but makes for some funny times
If you don't have a fmic, or at less a highflow side mount and you have a t04e then you're crazy.
cheers shawne :P
I was told that it will cause turbo damage over a period of time.
thanks boys thats awsome but i love that massive flutter sound i might look into it a bit more and get back to ya .
also without the bov . dose it matter that its externaly gated ?
if you no what i mean ?
cheers
Then don't use one, but it will cause damage over time. As for the BOV being externally gated....are you talking about the BOV or wastegate?? If you have a BOV venting to atmosphere then yes it is illegal. You can have an external gated turbo, which has a wastegate on exhaust manifold, to be legal that has to be plumbed back into your exhaust system further down.
yes.
I don't think you can win either way, best going with what drives you least crazy listening to over and over again.
I hear ya rob. I've been ''dosing'' for about 18months, and my mechanic has aswell for YONKS, with absolutely NO damage. So the whole argument about its 'fulleybadforurturbo'is BS.
I switch between bov and dosing. It just gets boring :P .
sorry about that i ment that the turbo is externialy gated and why is it that if you run a bov into atomo , its illegal ?
Anything that vents gases into the atmosphere is illegal.
Wategates are only legal if they plumb back into your exhaust (if it doesnt plumb back its called a screamer pipe and that makes it illegal)
Same goes for bov, If it is plumbed back into your pipe work its legal (if it doesnt plumb back into your pipe work and just releasles into the atmosphere it illegal)
Does that make sense ? ? ?
    • I believe Unimog is the only vehicle that has it (from the manufacturer). I haven't seen aftermarket permanently connected kits, but I haven't looked either.
    • Ha ha ha, can't overthink when exhausted... Oh how I wish I had that power! I can be absolutely dead set shot, and my brain will still go "we need a good 3 or 4 hours to just think about everything and anything before you may sleep... My biggest thing is making sure I give myself enough sleep. I don't operate on even 7 hours of sleep! I attempt to give my body 9.5hours sleep a night to be able to function. I don't sleep the whole 9.5, but I need to make sure I offer a big window. I also take a single supplement, which is to help with long term health, and fighting inflammation, and I notice it helps massively. Especially me sleeping, and just less "achey" in the body. Have also kicked sugar, and gluten. A majority of people with ADHD don't go well with gluten. It causes a really interesting natural opioid overdose in the brain, which causes bodily issues and sensory issues.
    • Yeah that's what I meant, permanently connected not manual
    • Yep. But typically that's just run a hose down to the tyre while stationary.   Oh and the Unimog will automatically air up and air down tyres from the onboard computer for you too.
    • There was a good video somewhere, maybe Kurzgesagt that linked physical activity to ADHD/Anxiety/Insomnia etc. Basically the body WILL spend energy doing something if you don't spend it doing anything physical. It isn't fun, but I personally have noticed I've never been overthinky, or unable to sleep if I'm physically exhausted from doing a lot. The musings around it seem to indicate that this is one of the reasons/mechanism that physical activity improves mental health/wellbeing etc, by more or less not using that 'extra' energy to overthink, be anxious, inflammation, etc. There's also the fact that every obnoxious exerciser ever says it's great and helps which is extremely annoying. Like people who say the same thing about travel being the best thing ever. I mean, they clearly are, but blah. I started doing a LITTLE myself (think 3x15min per week) and honestly did notice the benefits, aiming at life quality when older. Which is sooner than you think. Getting something into your routine that you can actually make a routine has helped me at least. This post brought to you by procrastination between sets.
