If you can get hold of a broken one theyre relatively easy to fix if you can solder. Only problem is getting the plastic pieces apart
You can get cheap replacement ones from autobarn but the holes dont line up so you'll have to use double sided s/tape. Enough if you want a roadworthy/safety cert.
