Ive decided to hold off on Hp mods for a while now and concentrate on the interior to a degree. To say it was in a poor state is an understatement, the dash etc is all it top condiction but the floor mats are very worn and there is a lot of dirt and general mess in the car. Here is a few photos
I then decided to make a few purchases that will hopefully make the interior look cleaner.
First purchase was Bride Low Max seats & Rails to suit
Firs order of business was removing the standard seats
Once that ones done i attached the rails to the seat and bolted the new seats in. I did not that the rail wasnt the best for a dorect fit, but after a few jiggles here and there it fitted. I only had enough time to do the drivers side before i had to go to work this morning.
I couldnt resist so i drive it to work to test the fit and I'm impressed with how tight the fit is. Its the perfect size for me.
More to come this week...
I havent had trouble on the drivers side at this stage. I had mor trouble with the centre console and getting the rail to sit far enough to the left to match up the holes. Once i got the bolts in and started to tighten them all down it starting coming into place and ended up fine
Ended up getting the second seat in today.
Also bought one of these to give guard rolling a stab. I already have some rust issues in the arches so i thought i might as well try and roll them before getting it fixed.
Messenger_5827201667930251191_1389313141
So i attempted to roll my rear guards. Ive never tried it before and my rear guards already have some rust issues that i need to address so i though i might as well roll them and if i screw it up i needed to fix them anyway.
First of all I put the car up on stands
Then wheels came off and I got prepped with a mallet and a heat gun
Once i had bashed in the lip a fair bit i was able to attach the roller and use it to move the lip
Once i was happy with the lip i then started to push out the edge to pump the guards a bit. Here is some photos of the LH Rear and the lip work on the inside
Here is a comparison the the RH guard before i hit it with the roller, bit of a difference
Now i was time to try it on the more difficult size with the major rust problem. Ive had this issue for sometime with this car and having rust on the edge of the wheel arch and have just pretty much ignored it through laziness. Obviously this is not something I recommend people doing when it comes to rust.
I knew things had to get ugly before they got better so off i went. As soon as i started t hammer away the guard starting to crumble as i expected. Here is so pictures of it for those playing at home
Here is the best i could make of them at this stage
A this stage I'm just going to hit the rust patch with some white 2-pak paint until i can get it to a panel beater over the coming weeks.
There is another Downshift meet at QR this sunday so it will be good to take it out to the track with the higher power output than last time I was there
that rust is nasty!
but can be fixed. Just need to ensure the rust is fully removed before you weld another sheet of metal over it.
With having to get this rust fixed and the odd bit of panel work here and there to bring the body up to scratch. I'm currently tossing up the idea of giving the car a full respray in the process. Whats peoples thoughts on colour choice. I was looking at a bright red if I was going for a bright colour, otherwise maybe a more subtle silver or something
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
    • Like a Stagea, but not as cool! Hope you have enough garage space for this, or is something going to leave to make way for it?
    • The new project has arrived. I have wanted one of these for such a long time, well before that meathead Clarkson drove one in Africa. I really wanted an E34 but I have some medical issues that mean I *really* can't bump my head and the lack of airbags in the E34 made it just too big of a risk.  I don't know why I've always liked these older touring BMW's to be honest, but man I love this car. She's been pretty well maintained for her 243k's with what appears to be only a single oil leak at the oil filter housing gasket. It has a bunch of updates including later model bumper and headlights, 7 series billion-way adjustable seats and it came with a few spares and another set of wheels with legal tyres. I got a unregistered car permit from the RTA and drove it back from Canberra on Saturday.                   First cab off the rank is cleaning it up for blue slip. I dont know how picky they'll be but I figured I'd clean the headlights, fix the oil filter housing gasket, replace the speed sensors (throwing errors) and swap the OE wheels (the M Sport wheels have a big chunk out of one of the tyres.) I also need to replace all 6 gas struts - 2 for bonnet, 2 for hatch and 2 for hatch glass. The car tries to eat me whenever i open any of these. My plan for this car; Ultimately, this is a budget car. I can't afford to throw lots at it and its because I have another car that I got this, if something breaks its no big deal. I will just maintain and repair it really. But eventually I want to do a manual conversion. It actually looks pretty straight forward for E39's and the trickiest part will be sourcing the parts.  I do need to replace some suspension arms or bushes because wow, she's a floaty old girl. She's also fantastically slow. Like really, really slow. When pulling back out on to the freeway on Sat after a quick pull over I needed to wait until no cars were visible before going.  Oh, and the guy I bought it from had a gorgeous R31 GTS-X in the garage.
    • Do you have a picture? I assume it is a breather for gearbox oil as it expands, it should have a vacuum line run nice and high in the engine bay (R32 GTR has it on a top bellhousing bolt)
    • Hi all, I am putting an r33 gtst gearbox into a VL and have noticed what looks like a vacuum barb on the box (on top in the middle). Suspecting that it's a vacuum line but I'd like to double check, if someone could confirm the function of that would be great. Cheers in advance.
