New radiator in. I accidently ordered the 42mm radiator instead of a 52mm. However its seemed to have worked out so far and ive even been able to keep the fan shroud in there nicely
Also got new shelving for the garage to tidy things up a bit
there is room for more shelves Scottie........dooooooo eeeeettt
Radiator is sweet. Keep cooling fan shroud as it helps keep things........well cool
Its a spare one i have lying around.. Ive got one on the car. May install a dual system if needed down the line
ok good.
Additional oil coolers will certainly help ie diff / transmission cooler etc...
Went for a few short drives today to test out the new radiator and make sure it was working fine. First lap ended up in ditching the car in favour of walking to get more coolant. But after i topped it up it has been fine since.
Also these arrived today
Fark those tyres must have cost a penny or two... I considered buying a pair of 16" wheels once, just to get away with paying for a smaller tyre. So many golds.
$355 each! Was only going to save about $10-$15 each if i went to a smaller rim. As i already had a pair of 17's at home I thought this is the cheapest option for now and would be a good indicator of where the traction is at and if I need to go smaller
Even with the 255/60/15 version of those I'm still baking 3rd lol
Wow! Thats interesting as thats a pretty big side wall. Hopefully these work out a lot better for me. I might give them a few KM of street driving and testing before Powerplay on May 10th.
The thing i like about the 17's is they arent so in your face as a 255/60/15 if you know what I mean? I like to keep a good street look about it and not have 15" steelies on the rear with big ass tread. But for track work I guess it could be alright.
Tune day confirmed tomorrow at 10am! Was going to drive the car down to the Gold Coast for it, however with it being Easter holidays and increased police presence I thinking trailer might be the better option. Cant afford the double fine and double points lol
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
