Just looking at converting to E85 is all thought I'd ask a few questions on the conversion
It's definitely worth making the switch. Too many easy gains from it not to and it's becoming more and more readily available
Gee where to start, Needless to say the last week has been pretty full on.
After many a delay I finally got the car back on Friday. After noticing the car was on the dyno at 10:30am on Friday I expected to get a call around 12:30pm-1pm stating that its done. It came to 3:30pm and I hadn't heard anything so I gave them a call. Apparently the car ran out of fuel on the dyno during tuning and they had to go get some more (I dropped it off with a full tank). I let them know it takes me 2 hours to get there so if they know when it will be ready i can start heading there earlier so they arent hanging around waiting for me all arfternoon. Finally got a call back at 5:30pm stating that its nearly finished and to head down.
They advised on the phone that it made 630rwhp on 29psi, however the head was lifting and they wanted to "dial it back" a bit to make it safe for powerplay.
Arrived there at about 7pm and got chatting about the car. Even though the car has ARP head studs it was still lifting. I thought "righto at that pressure I guess it needs looking at". Then came the "Dialed Back" numbers. They ended up bringing it all the way back to 451rwhp on 15psi. I still and even now am surprised they had to drop it back so much to make it run safely. Due to the time of night and a bit of disbelief on my behalf I didnt go into depth about the lifting issue etc.
By the time we got the car loaded onto my mates tow truck and got it back home & back into the shed it was 11pm. After finishing off other setup jobs for powerplay the next day I got to bed at 12:30am.
NOTE : I DO have dyno sheets for both the 630 runs and the 451 runs. I will scan and upload them hopefully tonight.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
