Just looking at converting to E85 is all thought I'd ask a few questions on the conversion
It's definitely worth making the switch. Too many easy gains from it not to and it's becoming more and more readily available
Gee where to start, Needless to say the last week has been pretty full on.
After many a delay I finally got the car back on Friday. After noticing the car was on the dyno at 10:30am on Friday I expected to get a call around 12:30pm-1pm stating that its done. It came to 3:30pm and I hadn't heard anything so I gave them a call. Apparently the car ran out of fuel on the dyno during tuning and they had to go get some more (I dropped it off with a full tank). I let them know it takes me 2 hours to get there so if they know when it will be ready i can start heading there earlier so they arent hanging around waiting for me all arfternoon. Finally got a call back at 5:30pm stating that its nearly finished and to head down.
They advised on the phone that it made 630rwhp on 29psi, however the head was lifting and they wanted to "dial it back" a bit to make it safe for powerplay.
Arrived there at about 7pm and got chatting about the car. Even though the car has ARP head studs it was still lifting. I thought "righto at that pressure I guess it needs looking at". Then came the "Dialed Back" numbers. They ended up bringing it all the way back to 451rwhp on 15psi. I still and even now am surprised they had to drop it back so much to make it run safely. Due to the time of night and a bit of disbelief on my behalf I didnt go into depth about the lifting issue etc.
By the time we got the car loaded onto my mates tow truck and got it back home & back into the shed it was 11pm. After finishing off other setup jobs for powerplay the next day I got to bed at 12:30am.
NOTE : I DO have dyno sheets for both the 630 runs and the 451 runs. I will scan and upload them hopefully tonight.
    • What could be causing my clutch problem besides a bad master or slave then? Both those parts are new
    • Just came across this, but in QLD I start leave again in 2 weeks, if it is still available I might drive up and check it out Unless, @MBS206 do you live near here????, if so I could hit you up with a finders fee https://www.gumtree.com.au/s-ad/hope-island/auto-body-parts/nc-mx5-factory-hard-top/1328976391
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
