Scr48 First + Only!
Picked up boot lid yesterday from a mates place who gave it a quick lick of black. At this stage im not sure weahter to keep it black or wrap in in CF vinyl like last time. I think as this stage ill leave it black and get all the holes for spoiler drilled in and then decide what to do.
fc127806065b1009f627473b7edf9f46_zps891d
Also picked up a new catch can setup that arrived yesterday. Its a 2L tank, think it may be too big to fit in the bay with that sized breather on top
hey man love the build good to see you get it going again think ive read through your thread twice since ive been on SAU. go Purple. i have a thing for purple. but i think your purple in your bay will look better than mine :).
Thanks Mathew, at this stage the covers will go blue as my mate has some of it lying around. Definitely will go a deep purple in the future.
All build threads start somewhere. I've owned this car for over 6 years and i've really only started pushing the limits in the last 2. Your car is a great base to start with and looks tidy!
Quickly threw the bootlid on tonight to see what it looked like. Terrible phone quality.
There's a newish CF vinyl which you can find on ebay called 'Carbon Fiber 4D' and it looks fairly legit compared to the old textured CF vinyl. I bought a sample and was quite impressed.
I might have to have a look at this. See how it looks when the spoilers finished and on then take it from there
Played around with the car a little bit today. Ripped out all the air con gear along with some other unwanted engine bay items.
Ive also stated the long process of degreasing the engine bay. One thing i have noticed is this will take a long time!
Air Con out. Didnt have a large enough spanner to get this out so it was a good excuse to buy an over the top spanner collection. 8mm-32mm should do it.
Here is a picture of the one area i cleaned today. Still a bit here to get rid of
Also here is a photo or the top of the firewall, jsut to show you a before and after with the degreaser
No offence but i hope you got the air conditioning gas removed professionally or removed by your self the proper way and didnt just let it out into Atmos
When I was restoring my GTR I didn't do that and all dat gas blew up everywhere
Got a little fright but managed to clean up all that green hew crap after lol
#dontf**kmyozone
Looking good Scottie
I don't mind the boot with no spoiler. Keen to see it when it's finished though. Rocker covers look mad.
I ran the no spoiler look for a long time till i got the drag wing. Once you see a 33 with the flush bootlid its hard to see it with only the stock one and still like it
#dontf**kmyozone
Thanks Ants. coming along slowly. the tough side is still yet to come. There is a lot more shit on the other side of the engine bay to work around. Baby steps
yeah that takes a real long time.
Make sure you apply a sealant like some turtle wax after to keep that engine a bit cleaner longer
Good idea, didnt think of that.
#dontf**kmyozone
haha oh well lets just hope it was some minus 30 shit and not r134a :P
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
    • So awesome! I love the RB with the exhaust on display.
    • NO HITS PRICE DROP   ENGINE - $8.5k ONO TRANSMISSION - $1.8k ONO
    • If it has had a code in the recent past, the code should still be there waiting to be read.
