  • 3 weeks later...
Not really much happening of late on this. Got some dyno time last week where we ran into issues with the head lifting. So off comes the head to sus it out and go again.
Car went 520rwph at 22psi before the head lifted. Hopefully more updates this week
  • 3 weeks later...
So finally brought the car home for a little while while i fit up some parts and enjoy the car for a bit, even if it is on low boost. Here's a vid of the cars first start up at home along with the exhaust tone at idle.
  • Like 1
First job was to test fit the catch can and make sure it all fits. Had to move my oil filter relocator as that was taking up the space the new can is going. I was limited by the existing line length so after having a look over the setup i was able to mount it under the car behind the cooler piping.
First off i had to buy all the lines and fittings. Anyone who's done this knows unfortunately this shit aint cheap :(
CC874A49-4996-460F-8A6D-8F3E611372D3_zps
Now the new Filter location
3C448AE7-5B2C-4E0F-9DCE-0B0870CD7096_zps
F5A928EF-6EB3-4CF1-8C4B-46F686351CCA_zps
Heres what its like with the front bar on. Nice and covered so it wont get hit with rocks etc. Might still make up a protection case to go around it yet
8A455487-C5BA-4F49-A9C2-1BCCE9250238_zps
And test fitted the can in the bay too
D234FF7F-2989-4912-8F38-B8796AF1D191_zps
  • Like 1
Cars looking awesome man! Been following it for a while now and it just keeps getting better and better, i was just wondering where you got the plate thats holding your coilpacks in place/ how much it was
Thanks mate! Been a bloody long road but its all part of the fun.
Coil pack bracket is a custom job that i got a fabricator mate to knock up. Wasnt the cheapest but I think it looks awesome and give its a very neat professional look
Yeah man it definitely makes it look alot cleaner, ive seen a few other setups with Ls coilpacks where they were mounted on the fire wall and it makes it look messy, im looking at doing it the same way you have just to keep it all tidy.
Few different LS coil options out there. Most of the people who are mounting them on the firewall or off the rocker cover are probably using LS1 coils. Mine are LS2 truck coils, different design and make up and are a lot smaller and user friendly.
    • Also did some work to the shed and a massive clean out of stuff. It's now got a small fab/dirty room and has helped keep shed cleaner. Built some new work benches and re organised things also got a TV out there so good having something playing while working on the cars. Got a pedestal drill and linisher off a mate that need to pick up too.
    • First thought, have your current injectors flow tested. If they test fine, keep the diagnostics going. It's not the injectors. If the injectors are the issue, find some new or used (cleaned and flow tested) injectors.  While I really love a good excuse to get a modern ECU installed, just needing new injectors probably isn't a good enough reason to do so.
    • A bit from column A, B and C. Mainly C   Update time, after deciding it was time to tick off a bucket list goal I finished up full time at MSR and have gotten back behind the wheel and making progress on the S15. Goal has been to drive Bathurst at an event and I have had my entry accepted for Challenge Bathurst in November. Since I don't want to go unprepared I need it running to test and get comfortable.  Been chipping away at it and started by stripping inside, getting it all cleaned and sealing some holes up. With stripping inside I removed the whole wiring loom and found a few surprises.......... its pretty butchered and shit branching and I'm not a fan of the haltech fuse boxes so it's all out and trying to come up with a plan to rewire it all either new fuse/relay box or pdm.  I haven't been happy with how I did the intercooler mounting and been wanting to tuck it up under rad support. O e issue with that is headlights will need a decent trim or get replacement covers. Took the time to mount it with some stand off's and new hardware. Stands are some m8 button bolts, washer, aluminium tube and factory radiator top mount rubbers. It's nice and solid also stiffens rad support which still requires some trimming. Bonus of factory rad mounting is used all factory hoses just need to weld a pressure cap to radiator now. Got sensor block and fuel filter mounted. Plan today is to get vac lines all sorted with push in nylon tube and design oil cooler mounting solution.  Been driving BRZ a heap and went out to Morgan Park for time attack and went pretty well for a wet day. https://youtu.be/gAlQgcQpWj4?si=kojOAOjhhX_X3AXR Getting pretty comfortable in it now and want to do a few more bits to it but restraining myself as don't need 2 race cars at the moment.
    • @sunsetR33 There is obviously a huge culture gap here. There is nothing in place like this in Australia, where if you fit a Mines branded pipe and later replace it with a Jun branded pipe, both pipes are essentially identical - BAM - huge penalties! Where is the Mines pipe?? You can't have a Jun pipe when you said you had a Mines pipe!  Makes no sense to me. Surely makes no sense to anyone else here either.  I'm sure a lot of us would agree that our registration/engineering system is pretty stupid at times, but it's not that stupid.  *** More serious question here. If you replace a factory rubber hose with a silicone hose, is the car illegally on the road now? Does it become legal if you have certification of what brand the silicone hose is? Then would it become illegal again if you replaced that silicone hose with a difference brand of silicone hose? And then would it become legal again if you had certification of the new brand of silicone hose?  I really want to know that answer to that question.
    • Good you making progress with this rig. Aluminium welding is painful to learn, have you got a pedal as I found it so much easier with one. If that's the AMG I think it is, you would working with Benny?
