First test drive proved very enjoyable. Driving a big stalled auto is definitely a lot different to a manual setup.
Saturday Night Roll Racing at Queensland Raceway back on the 14th was the cars first event. Anyone not familiar with this event up here, it's an awesome and relatively new social racing event similar to a happy laps or powercruise session. People line up in the staging lanes and in pairs roll around to the main straight and drag each other. The nights very social and is as fun off the track as it is on the track.
a few days prior to the event I got a fabricator mate to pop around and we had some late night fab fun putting a side pipe on the car. Personally I think it turned out awesome. Bolts on and off just after the gutted cat is tucked up high on the car for good clearance.
A2B4CEC3-EB4A-404A-9788-383FB88F6E6F_zps
Here is the side pipe when its off the car
0684DA69-87CD-4030-8C02-C3C781128137_zps
Some of it on the car
F7BDEDA5-C558-44B0-9E0D-67BE75C1740B_zps
FD22848F-8A5F-474B-AFA8-8D0E747BE2AA_zps
Now for the idle video!!
  • Like 1
Now it was time to actually take the car out there and have some fun with it. To be honest I was more nervous than I thought I would be, it was excited nervous but nervous all the time. Took the first few runs relatively easy just to get a feel for the new setup and how it would react, specially the gearbox.
Mates got a video of the maiden run for the car. Wins a win even if its not overly fast
  • Like 1
Took a mate for a ride later in the night and got an in car video of a race. As you can hear 2nd gear is a bit of a write off as it just wanted to break traction and get loose. New to the setup I decided it best to get out of it and back on it rather than drive though it.
All in all the night was awesome and got a great felling of accomplishment finally getting the car out to an event. Few teething issues here and there to sort out like any brand new build but all in all a successful first night out.
  • Like 1
What power is it making on e85 again?
Currently tune is very mild. 500rwhp at 25psi. TH400 is a power sucker, however the cams that are in the head are too small for the size of the turbo and we arent seeing good enough gains per PSI of boost we are adding so we brought it back to have fun at the track last weekend.
Cams are In:264 Ex:272. Inlet is the big killer
Turbo: 80mm Billet Turbocharger
  • Like 1
More info on crank trigger setup please.
Some good photos of it a few pages back.
Both cam and crank triggers use Honeywell GT 101 sensors. There is also a small 12 tooth trigger wheel that sits between the balancer and the timing belt cog
  • 3 weeks later...
Pretty quiet on the car front for the last few weeks, busy moving house and life in general.
Contemplating a few different things to change on the car. Typical RB life has me pushing decent amounts of oil into the catch can. Thinking of putting on a "Pre catch can catch can" i guess you could call it. Here is a few mock up pics of what it would be. Hoping that gravity helps keep at least some of the oil inside the covers lol
C5194459-8246-4942-A86E-EFF4CB7F1901_zps
4A533956-FD9E-44B1-A379-F02FF61E4F5A_zps
174C7A81-788B-4F8B-9583-7E793D50E6CD_zps
  • 6 months later...
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
