Ive decided to hold off on Hp mods for a while now and concentrate on the interior to a degree. To say it was in a poor state is an understatement, the dash etc is all it top condiction but the floor mats are very worn and there is a lot of dirt and general mess in the car. Here is a few photos
I then decided to make a few purchases that will hopefully make the interior look cleaner.
First purchase was Bride Low Max seats & Rails to suit
Firs order of business was removing the standard seats
Once that ones done i attached the rails to the seat and bolted the new seats in. I did not that the rail wasnt the best for a dorect fit, but after a few jiggles here and there it fitted. I only had enough time to do the drivers side before i had to go to work this morning.
I couldnt resist so i drive it to work to test the fit and I'm impressed with how tight the fit is. Its the perfect size for me.
More to come this week...
I havent had trouble on the drivers side at this stage. I had mor trouble with the centre console and getting the rail to sit far enough to the left to match up the holes. Once i got the bolts in and started to tighten them all down it starting coming into place and ended up fine
Ended up getting the second seat in today.
Also bought one of these to give guard rolling a stab. I already have some rust issues in the arches so i thought i might as well try and roll them before getting it fixed.
Messenger_5827201667930251191_1389313141
So i attempted to roll my rear guards. Ive never tried it before and my rear guards already have some rust issues that i need to address so i though i might as well roll them and if i screw it up i needed to fix them anyway.
First of all I put the car up on stands
Then wheels came off and I got prepped with a mallet and a heat gun
Once i had bashed in the lip a fair bit i was able to attach the roller and use it to move the lip
Once i was happy with the lip i then started to push out the edge to pump the guards a bit. Here is some photos of the LH Rear and the lip work on the inside
Here is a comparison the the RH guard before i hit it with the roller, bit of a difference
Now i was time to try it on the more difficult size with the major rust problem. Ive had this issue for sometime with this car and having rust on the edge of the wheel arch and have just pretty much ignored it through laziness. Obviously this is not something I recommend people doing when it comes to rust.
I knew things had to get ugly before they got better so off i went. As soon as i started t hammer away the guard starting to crumble as i expected. Here is so pictures of it for those playing at home
Here is the best i could make of them at this stage
A this stage I'm just going to hit the rust patch with some white 2-pak paint until i can get it to a panel beater over the coming weeks.
There is another Downshift meet at QR this sunday so it will be good to take it out to the track with the higher power output than last time I was there
that rust is nasty!
but can be fixed. Just need to ensure the rust is fully removed before you weld another sheet of metal over it.
With having to get this rust fixed and the odd bit of panel work here and there to bring the body up to scratch. I'm currently tossing up the idea of giving the car a full respray in the process. Whats peoples thoughts on colour choice. I was looking at a bright red if I was going for a bright colour, otherwise maybe a more subtle silver or something
    • Shit thing to find eh? I guess the big issue is that whatever "fix" you do now, it might slow the rust down but won't fix it. I just wanted to add that in no way is fixing sheet metal in 3 dimensions the place to start with welding....that is a pro only job because its too hard to work out where things should be, let alone doing a clean enough job that it can look OK and still be strong too.  I needed to get a new rear quarter panel on the GTR and it took a pro weeks to get the old one off cleanly, new one on in the right place and looking somewhat like it should have with most of the previous connecting panels in place. Gluing a couple of bits of metal together with a welder in the garage is doable, but that is totally different to doing panel  replacement
    • This seems to be a very popular swap since all the turbo skyline prices went through the roof! I'll let someone more familiar chime in, but I understand that yes you probably want to swap the loom in to swap out the auto TCM stuff. You should not assume everything just plugs in either, you need to check at least the ECU wiring diagram for any differences at the plug at the left headlight and probably the ones near the ECU that join the dash loom too
    • hows it fellas, my first post here which seems crazy cos half the forums i read are like the same age as me haha. to make a long story short ive got an r34 sedan (rb25de neo auto) which im swapping to a s0/s1? rb25det, r33 big box and nismo gt pro lsd. i have the motor and gearbox all bolted up outside the car, old motor and trans out. i bought the motor with stock ecu and loom, do i switch over to that? or will it be easier to get a r34 manual ecu and keep the loom if thats even possible.  also engine mounts look different, anything else thats different or incompatible? cheers, hope this all makes sense Paddy
    • att.4QNbuJlz_gNZPFBGFqeEvxSUHXkGt7z40V59MrtXTPg.mp4
    • Plan on the day will be to park trackside. Depending on space availability we will try put a small shade tent and a few of the cars on top of the hill inside turn 3, this is an easy to get to parking area with views of Turn 2, Turn 3, Turn 4 and Turn 5 and limited other pieces of the view around the track. IMPORTANT NOTE! One consideration from previous years is from memory the trackside parking sells out before the admission tickets, for that reason I encourage anyone planning on coming to buy tickets for parking now via the official website; https://www.worldtimeattack.com/ The type of parking you are looking for is 2 Day Park & View (Access Around Venue) Vehicle Pass Only Please note this does not include admission to the event itself, remember to grab that also, and kids under 12 get in for free!
