i just finished my 2years in the army and im currently a 20yo international student in perth and im gettin my P's soon. Do you think its a good idea to have a skyline for a first car? Whats the diff between a rear wheel drive and four wheel drive?
Is it better to buy my car from private sellers or dealers?
Thanks in advance!
https://www.sau.com.au/forums/topic/29031-just-some-questions/
Hello and welcome.
for a first car a skyline is awsome.depends on how much dollars you have. you can pik up a nice R32 GTST for arounr 15 - 18 grand.
They also come in 4WD ( GTS4 Version , also turbo ).
but the normal GTST is RWD. the only differnce i would say is 4WD would be a bit faster and would handle better , but cant do burnout :P . and the RWD would be more dangerous , unstable in the wet i suppose. but its all up to personal preffernce and also comes down to the $$.
Thanks, hope this helpd
Hi xsoulx, welcome to aust and SAU.
I highly recommend you go out and test drive a few cars. At the end of the day, what one person thinks is awesome, another may think is average.
Rearwheel drive: only the back wheels are driven by the engine
fourwheeldrive: all 4 wheels are driven. with the attesa (nissan 4wd system) they are not constant 4wd, like the subaru are. the 4wd comes on when slip is noticed on the back wheels by a computer.
4wd generally will mean you can get off the mark quicker when taking off, also gives you a pretty big advantage in the wet, and was where the GTRs really came home when they competed in the touring car championships here is aust.
Skylines are great cars for all people. As with all people who are just starting to drive, know your limits, and dont think you are Micheal schumaker just because you have got your liscence for a few months and you should be fine. Its the driver that makes a car dangerous, not the car.
As for buying, make sure you get the car checked out thoroughly before you put a deposit down if you are buying private, and if you are buying from a yard, make sure they have aftersales backup and service.
You get more car for less when you buy private, but you can get good backup and piece of mind from business - they choice is yours.
4WD is faster how exactly?
in the wet and off the mark im imagining :)
soul, brother, theres no "good" or "bad" time to buy any type of car. if you can afford it - buy a fast european car! porsche 911, e46 M3, ferrari 355...whatever!!! you only live once dude :) the only reason why im not driving one is because i can't afford one :) so i drive fast japanese cars instead - which are cheaper :)
gets the power to all 4 wheels - 4 wheels pushing the car forward instead of 2 - faster off the line. that and the 4wd means GTR -->twin turbo --> more power
I think you need to learn more about how cars work. Not to mention why exactly a GTR has more power than a GTS-t. (hint: it's not specifically because it has an extra turbo)
hey gents, settle down, we've all had to learn these things at some time.
And for the newer members posting here, please keep in mind, if you are not *certain* of something...don't post as though it is fact. Other ppl may take what you say as gospel...
I don't have a problem at all with people that don't know stuff. I am more than willing to give advice and help where needed, in fact I like helping people :) But you covered what I have a problem with in your second paragraph - if I'm not sure of something I'll either say I'm not sure or say nothing at all. I don't go around saying things as fact that are obviously incorrect.
One thing that hasn't been mentioned here is that a person on P Plates is banned from driving a GTR by the RTA, hence the reason I bought my GTR at 21. This is the case in VIC, cannot comment for WA. You can ask the RTA to fax you a list of the 'banned' cars list.
But bottom line is that it's only illegal if you get caught and at a guess 2% of traffic cops could tell the diff between GTR / GTST. So go the R! U wont regret it.
    • That's the thing....the basics of fuel and ignition are deceptively simple.....getting it to behave like factory in all conditions after airflow mods is way more complex. Newer cars like the V37 are all about modifying the standard ECU which is about a billion times more complex than they were 20 years ago, with a bunch of parameters affecting others
    • The larger TB I had on the SS was a pain to get to idle right, but, that was cable In the end they just raised the idle up a couple of hundred RPM so it was happy idling away either in gear or in park (slush box life) I'm curious on how my NC will idle with the new intake, larger TB, and cams that are currently going in/on, but I have faith that MX5 Mania will sort this "electronical" "black magic" out the best they can in the tune with a electronic TB Sometimes I wish I knew more about the intricacies of tuning, but most of the time I don't because I know it would hurt my brain 馃ぃ
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
    • The GTR strut brace clears the new manifold.. by about 0.5mm. So this means I need to buy an OEM GTT Strut brace (again), which will clear the new manifold, but not the bonnet vents. I guess I can sell the GTR Strut brace with the bonnet with the vents as a package deal as someone will need this one day. So my choices are vented bonnet but no strut brace, or GTR Bonnet with OEM brace (which I have to buy) but is bright red instead of the same colour as the rest of the car, which means the entire front end of the car will just be red until it goes back to paint jail. In other news the engine starts and doesn't leak. Why both O2 narrowband sensors think the tune is rich AF I do not know. The idle is also pretty shitty and my expensive IAT sensor from the USA is dead. The car sounds awful. But I assume or at least hope this is due to the many exhaust leaks, and the concrete garage it is in, sitting there with 0 intake bolted to it, and no bonnet or panels or anything to stop the induction/intake sound which is about 200db.
