when i have been pulling into the carport after work, as i slow down and near full lock and just let the auto pull me into the parking space, the car shudders and looses rpm
i have only noticed this of late with the need to use aircon.
i'm thinking it is the engine at idle turning both the powersteering pump and a/c compressor making it hesitate
is it an issue, common, really worth me worrying?
does it do it any other times? I had an issue where the steering would cause it to lose revs and sometimes stall when driving at low speeds, and very often when pulling into my driveway in a block of units (full lock one way then the other).
First I had the power steering fluid flushed (that was all nissan could find) which kind of alleviated the problem ever-so-slightly for a few days...and then it was back again.
But it turned out to be a build-up of black around the butterfly on the intake, making the butterfly sticky and so it couldn't adjust the idle quick enough. The M35 has no idle air bypass valve so it relies on the ecu adjusting the throttle to let the right amount of air in.
If you have some time, remove the throttle body and give it a good clean out. This fixed the issue 100% for me and straight after that it idled perfectly every time. I did have to do the idle-relearn procedure afterwards to make it idle at the right revs again (i think there's a sticky in the DIY or servicing section at the top of the forum).
Some other guys had the same or similar problem although not all of them were the same cause...
If you find the solution, let us know :cool:
thanks for that - it is very occasional but when it happens you notice it.
i'll give that a try one day when i'm bored and inspired - it causes no issues, just curious to why.
your example seams very plausable i'll try that first
cheers
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
