Update time guys:
ECU's Sent To NIStune
- QWK32 - 19/10
- hibino - 21/10
Second payment was sent this morning guys, so msports180, Stagea_Neo, canarygsr, stagman and SABBAi, give it a couple of days to clear, then you've got between then and early December to have your ECU's sent to Matt.
I need the email addresses of the following people:
- canarygsr
I also need a return address, car make and model, plus ECU serial number and part number from the following people:
- msports180
- SABBi
- darrinspencer
Sent ya a PM a few days ago with mine? If u didnt get it lemme know and i will resend.
  • Replies 124
Posted Images
sorry i haven't been around for a while guys. been pulling all-nighters to get a product finished and the internet connection here is shathouse (i've been doing some of this on my phone to give you an idea of how painful it is at home, lol).
I've just (begrudgingly :P) cleared out my pm's because my box was full. if anyone was trying to pm me and couldn't, please re-send :P
[email protected]
did he say how long until he sends out to the guys who are installing there own?
i've had a pm or two from guys asking when the daughterboards will be sent out to DIY'ers. has anyone received theirs? I've just emailed Matt asking how he's going with them.
apologies, i do have it here :P cheers for the reply :)
Update:
- QWK32 - 19/10 - Received
- hibino - 21/10
- darrinspencer - 22/10
- SABBi
hey guys,
got an email from Matt last night. the daughterboard only orders are being posted out today :D
Can the following please PM me with details:
Stagea_Neo: i need your full (first and last) name for the software key.
SABBi: I still need your details mate.
JRM: I need your ecu serial and part number.
canarygsr: Matt needs the rom image from your ECU. i got a cc of the email he sent you, so have a look in your hotmail address.
hibino: your ecu is being posted back today.
cheers guys
josh
Edited by pyro-ns
Boards have been posted out this morning except for the two Stagea 23740-0V811 boards on the second group purchase which I'm chasing a ROM image for
Code 21: Ignition Signal
Code 26: Boost Pressure Sensor
Code 34: Knock Sensor
Code 43: Throttle Position Sensor
These codes are a result of running your ECU on my bench setup with not all the sensors connected at that time. Once you hit the 'clear DTC' button on the consult display they will go away :D
if i get the same CODE error issue's how can i solve that on my own ?
i think there might be away to reset them using the same method as checking codes buy bridging the two point on the consult connector. Link to Ecu Diagnostics
other options are, check to see if someone on the forums that lives near you and has consult cable and software can reset them for you. ring a few workshops near you, some will have some sort of OBD diagnostic scan tool and could reset them for you. or even some one with nistune software, i saw in there you can clear ecu codes, just like Matt said,
once you hit the 'clear DTC' button on the consult display they will go away
i've had no troubles and no error codes thrown since i reset them once i re-installed the ecu.
Hi Josh,
I've sent you a pm late last night with a recap of all my details.
Regards,
Pete :banana:
hey guys,
got an email from Matt last night. the daughterboard only orders are being posted out today :)
cheers guys
josh
mine sent this morning, express. hope i get it back by the weekend. need to shift a house :S
is the car able to be driven with the errors showing up ?
lol, the whole house!! :D
my car still ran with the errors but i reset them straight away, so i dont know if the ecu went into any sort of safe mode/limp mode. if you get them try the diy way with bridging the two pins on the consult port, you bridge them once to bring up the error codes and bridge again to clear them. if not i'm sure you'll be able to find someone open to clear them for you, even a nissan dealership service centre will be able to do it.
Edited by QWK32
Update:
- hibino - 21/10
- Stagea_Neo - 27/10
- RBPowaTJ - 27/10
Daughterboard Orders Received
- stenve - 27/10
- SABBi
I need ECU Serial and part number from the following people:
- JRM
Hi Josh,
Regards,
Pete :cool:
Received and passed on. Thanks mate :/
i never got an email ??
i've forwarded it on to [email protected] :D
I think they tried to deliver mine today. I got a letter in the mail saying to go to the post office to pick something up :)
I'll let you know.
don't ya hate that. then the bastards are never open when you have time off or anything.
also, can someone confirm this for me. to clear error codes, can't you just disconnect your battery for 5 mins or so?
Edited by pyro-ns
Guest
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
