It's been discussed before, but I can't find answers to my questions in a search, so here I go with a new thread. (security should remain a forefront topic anyway).
The background story: I was all set to get a Brant alarm/immobiliser to replace my old paging alarm, which has a dead main remote (using spare atm). I rang Brant up for a price. It's $1000 for their Nemesis, or $650 for their AA02A which is essentially the same but with 3 immobilisers instead of 6.
I was considering getting the cheaper model, mainly because (a) fuel pump cut is totally useless in R33's which has the battery next to the pump (just run a short wire), and (B) I didn't think it was worth the extra $350 for the extra 3 immobilisers all of which can be easily defeated with a tow truck.
But then I found that it's an extra $150 for the window winder modules, and neither has a paging function or turbo timer, and I think and at this point I started to think that it was a bit of a rort. They may be the best alarm out there, but even the best alarm will not stop your car getting towed.
Now onto the main subject
Because of the above I am thinking to get a cheap (~$300 or less) paging alarm with 1-2 immobilisers, and then save up until I can afford tracking. Most of these cheapie alarms have all the good stuff like window winders and turbo timers and remote starts etc.
The prime candidates are two paging alarms I found on Ebay, the Mannix Millennium and the Giordon 686. Both of these are dirt cheap ($150-$250 plus delivery) and seem to have all the good stuff with 1 immobiliser, which I'm sure could be rigged up with relays to cut more than one thing. If this relay is really hard to get to (ie, remove pieces of dash to install) then it should be virtually as good as 3 separate immobilisers.
Does anyone know anything about these 2 alarms or any reason why I should steer clear? I'm not going to rely on the paging system, the main reason I like paging alarms is because of the screen they have which verifies the car's status at a glance. Please suggest better ones if you know of any, and where to get them. Until I can afford a tracking device I also want to install one of those mobile phone pager things.
Oh yeah one more thing. Is there any reason to NOT cut power to your ECU with the immobiliser? I would like to cut power to at least one item in each section of the car (boot, cabin, and engine bay) to make it a total PITA for any potential thief to run power to everything I've cut.
https://www.sau.com.au/forums/topic/29034-cheap-alarms/
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for ?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for  >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate modern almost all cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
    • Let's be wary though, if cranking is so far off, what else isn't set right? Are the dead times set right, voltage compensation etc?   It definitely sounds like it's cranking fuel issues, and holding flat to the floor is shutting them down, but I'm with Duncan that if nothing was changed in the ECU at all, and then this started, I'd be more thinking a leaking injector.   Do as Duncan said, drop the oil and make sure it's not full of fuel.
    • It actually means give it less throttle.
    • Yeah if the goal is to drive something then modifying a car is a bad idea.
    • Wowee! She looks like a major handful out there Pete!
