Hi all,
I've found IT! I have found THE front bar that I like best on an R34 GT-T.
Here it is:
If you look closely, there's also a little "lip" piece that extends the bonnet. Making it look meaner.
Now, bugger if I can find what front bar this is. I have looked all over the place. Everywhere. I can't even find another Skyline with this front bar. I have done enough research to know that he's got IMPUL sideskirts on it. I like them too.
In fact I love this car. I even love the subtle decals on the side. I want one! If I can get this front bar + lip extension (any ideas what it may be?!) + sideskirts I am definitely buying an R34 GT-T.
https://www.sau.com.au/forums/topic/29037-r34-gt-t-what-is-this-body-kit/
Who's this Frankie Lee guy?!
That's it! Minus the little front bonnet lip! (which may be custom made?).
It's not the East Bear but cheers for the link and leeds guys. Getting there.
hahaha, im Franky Lie :) with a "y" tony!
anyways, that front bar is a Top Secret bar. mine is a COPY version of it. i got my front bar from www.carmate.com.au fitted and supplied for around $800.00. Carmate is in Sydney's south west area.
this is what i had when i bought the car, its an original front bar with an east bear front lip. imho, better looking than the Top Secret bar, but farken tooooooo low. i cracked it within weeks of putting it on.
so i got it replaced with the aforementioned,
unsure about that nose extension, but damn, if you do find out where i can get one, LET ME KNOW :P
im looking at further modifying my front bar, it needs to sit about an inch lower and i want some ducting channels to the front rotors. if you're interested in one when its made up talk to me offline. i've already approached a bodykit manufacturer and the wheels are in motion :)
Cheers Franky for the info. So since you're going to add another inch to your front bar I assume you're not having clearance problems with this carmate bar? That's great. Perfect!
And that front lip. It looks like it's just stuck on there. I am in the proecss of contacting the owner of that vehicle above. He lives in Hong Kong. It may be custom made? It makes the car look a LOT better IMHO. I will keep at it.
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
