hey guys, selling my standard front brake setup.
selling due to upgrade to 4pots.
bendix pads front (2.5months old)
rotors machined when pads were changed and in good nick, no cracks/warps etc.
296mm rotor size
30mm thick
complete front brake setup including
2x calipers & 2x rotors.
maybe throw in brake lines too if the new lines i get fit my car.
check this out for rotor size comparison
after $140 neg pick up in syd.
pm if interested.
postage interstate extra, please pm me for quotations.
Thanks.
https://www.sau.com.au/forums/topic/290380-fs-r34-gt-front-brake-setup/
Shano, is yours a 25GT or 25GTV? In my case I sourced the R33 Calipers/Rotors/Hubs n Uprights. I was told that I would need them by a garage who'd recently done the same brake upgrade.
I took it to a different garage to do the job (didn't want to go up north side), and maybe the Sedan is different cause the bolt sizes on the R33 Hubs/Uprights didn't fit. Instead they simply modified the existing ones on my car to fit the calipers.
The R34 25GT Sedan has 280mm F and 265mm R rotors though so well worth the size upgrade either way.
On second thought, if you had a GTV you wouldn't be thinking of R33 brakes. If you need brake lines to suit R34 Sedan with R33 calipers, Goran at Brakewest should still have the info for the ADR Approved Braided Lines he made up for me. R34's need a lot of stopping power.. you'd think being a Sedan they would have opted for the larger brakes but nooo..
    • Atmospheric vent requires something that doesn't use a MAF for load. You would need a standalone ECU for that.
    • Hey all,   I’ve got an RB25 with a trigger kit that includes a crank wheel, and I’ve hit a wall trying to sort a timing belt tracking issue. The belt either rides right on the edge of the cam/crank pulleys or walks slightly forward once the engine starts. It tracks okay-ish for a moment, then creeps right to the edge—and honestly, it’s stressing me out.   I’ve spent hours removing and reinstalling the belt, double-checking everything:   Tensioner setup is good, checked multiple times Idler pulley and washers are all in the correct places Followed the RB25 timing procedure step-by-step     The only thing I changed was the rear crank washer—I swapped the OEM one for a Neato version, and it made things worse. The belt now sits even more forward than before. I’m beginning to think the crank trigger wheel itself (from the trigger kit) is the issue—poor design or slightly off dimensions.   What’s strange is that with the previous belt setup, it actually ran fine for a couple of years—around 4,000 to 5,000 miles, even with hard driving and high RPMs. But even then, the belt was always riding right on the edge, and I know that’s not ideal or safe long term.   At this point, I’m debating whether to:   Machine a few mm off the crank trigger wheel to bring it back in line, or Replace it entirely with a better-designed unit     Only thing is, I already have the Cherry Hall sensors, bracket, etc.—I just want to replace the wheel only, not the entire kit. Anyone know a brand or supplier that sells just the crank trigger wheel on its own?   Would really appreciate any feedback—especially from anyone who’s run into this exact issue and found a reliable fix.   Thanks in advance.
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
