hey guys, selling my standard front brake setup.
selling due to upgrade to 4pots.
bendix pads front (2.5months old)
rotors machined when pads were changed and in good nick, no cracks/warps etc.
296mm rotor size
30mm thick
complete front brake setup including
2x calipers & 2x rotors.
maybe throw in brake lines too if the new lines i get fit my car.
check this out for rotor size comparison
after $140 neg pick up in syd.
pm if interested.
postage interstate extra, please pm me for quotations.
Thanks.
https://www.sau.com.au/forums/topic/290380-fs-r34-gt-front-brake-setup/
Shano, is yours a 25GT or 25GTV? In my case I sourced the R33 Calipers/Rotors/Hubs n Uprights. I was told that I would need them by a garage who'd recently done the same brake upgrade.
I took it to a different garage to do the job (didn't want to go up north side), and maybe the Sedan is different cause the bolt sizes on the R33 Hubs/Uprights didn't fit. Instead they simply modified the existing ones on my car to fit the calipers.
The R34 25GT Sedan has 280mm F and 265mm R rotors though so well worth the size upgrade either way.
On second thought, if you had a GTV you wouldn't be thinking of R33 brakes. If you need brake lines to suit R34 Sedan with R33 calipers, Goran at Brakewest should still have the info for the ADR Approved Braided Lines he made up for me. R34's need a lot of stopping power.. you'd think being a Sedan they would have opted for the larger brakes but nooo..
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
    • from an old insurance company i was with (Budget Direct) I had someone roll back into me at the lights got them to pull over. Got a picture of thier licence with address, had a dash cam video and, thier phone number. But only had 3rd party on the shitbox i was driving. insurance did nothing, cops wouldn't do anything due to the value of the damage (under $3000) so i just had to suck it up and go to U Pull It.
    • Small Update on the Exhaust Situation A 200-cell cat was a bit too expensive for now, so I had the exhaust shop fabricate a new exhaust from the cat to the rear and an exhaust tip. I went this route to avoid cutting into the original exhaust and keep it intact. It’s essentially straight-piped, and the sound is noticeably different. The exhaust tip came with a silencer, so if it gets too loud, I can easily install it to tone things down slightly. Right now, the car bangs and pops like crazy -- which I personally love. In the future, I might add a resonator or a 200-cell cat, as niZmO_Man suggested, but for now, I’m really happy with how it turned out.
    • And that's a massive problem, because deadshits will deadshit and give you false details. At least in these days of mobile cameraphones, it is trivial to take photos of any ID they are carrying at the same time as the 300 photo extensive documentation of the state of the vehicles that I recommend even for minor incidents. And you get photos of the person's face, any visible tatoos, etc etc, while you're at it. Then you try to avoid mentioning that you're fully capable of making explosives of various power levels and will wreck their shit if you are forced to hunt them down.
