erm... When I said my brakes don't fade.. .I lied.. :D
I just took the car for a spin to try and get them to fade.
Initially from a 180km/h brake I can still lock the brakes on demand at what ever speed. be it 40km/h or 120km/h.
The second stop at first I can lock the brakes if need be but as the speed decreases to around 80km/h I have to stomp on the brakes pretty hard to lock them.
The third stop will pull up fine from 180km/h however i cannot lock them at all.
The fourth stop i can start to feel a bit of fade as the car feels like it is sliding (typical brake fade)
Fifth stop... pulled up ok but not really that quick. I pushed as much as I could within reason however there was no way I would stop quick a corner was approaching.
I happened to look down at my side mirror and I notice a little bit of smoke from the pads/disk area from the rear wheels as were the front wheels. Very smelly.
The brakes do not fade as quickly as conventional commodore brakes. With the old VS one second you had brakes the next second you had nothing. At least I get a bit of warning.
I will definately be upgrading disks and pads.
https://www.sau.com.au/forums/topic/29042-32-disks/page/2/#findComment-617819
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
    • Hi all! Looking to relocate the battery to the trunk of an R34 GTT. I want to do it using as many stock GTR components as I can (including the harness protectors from the 34 GTR that run underneath along the chassis to the engine bay). So far I’ve purchased the battery tray from a 33 GTR, as the captive weld nuts are already there just asking to be used. There is also the slight issue of now having to relocate the ABS/TC/Fuel Pump Control ECU, which in GTT’s sits right above where the battery will then sit on the tray. Has anyone already achieved this, and if you have any pics that you wouldn’t mind sharing? It would be great to see how others have done it and where you put them, as there are countless holes in the parcel shelf panel to potentially use. Just trying to get some ideas bounced around, and to help uncover any potential problems I may encounter by  my choice of location. TIA for any help!
    • Brand was ard.   I also threw a brand new battery at it and beefed up the wire from the alternator to battery and added an extra earthing point from the battery
    • Evening all,       I'm replacing some bolts on my RB25 with probolt Australia bolts.       Does anyone know the following, m5 m6 etc 10mm 20mm etc       Coil cover   Cam covers   Plazamaman fuel rail   Front cover (timing cover)   Etc   Any help would be awesome   Or any lists anywhere
