My dad borrowed my car to go to work last week (his was at the mechanic), unfortunately another road user couldn't tell the difference between red and green. On the plus side my dad walked away with only minor injuries.
I'm thinking about getting a Toyota Chaser to replace it depending on insurance costs. Does anyone here have comprehensive insurance on a JZX100?
Pics for your viewing (dis)pleasure:
https://www.sau.com.au/forums/topic/290462-careful-at-that-next-intersection/
Lucky there wasnt a passenger... I was hit in a similar situation, we were going under the speed limit so it hit just infront of the A pillar, lucky for the passenger.
Not going to be loyal to the RB and get a Stagea?
Makes me think of earlier today.
I was sitting a an intersection on a red light behind another car, with my mate driving behind me.
The light went green and the car infront of me was a bit slow to take off, and as he started to get going a Semi went flying through the intersection!
Just makes me think, I could have just witnessed someone being killed; or had that car not been there, my best mate probably would have watched me get cleaned up by a truck.
Edited by ss07
Holy sh*t, glad at least his ok.
I almost got hit on the side 2day as well, due to some stupid idiot in a POS doesn't seem to know that you suppose to stop & check for incoming traffic & give way to them when approaching a T-junction.
holy shit thats crazy. Poor R33 :P
I had a similar story, waiting at intersection to cross 80km/h road. Was at front, lights went green but was keeping eye on traffic on the intersection. Could see one car still going 80km/h and didnt look like was going to slow down.
Car behind me started beeping at me to move off but I still stayed at the green light. Next thing the stupid lady realises its red for her, jumps on the brakes and skids through the intersection stopping infront of my car.
If i went when it was green or when the idiot was beeping at me, I would have been cleaned up (drivers door too at 80km/h)
Lets just say the car who was behind me beeping at me avoided coming next to me at any other lights haha
Chandler and Cheltenham Road, always one hero flying through the red light heading towards dandenong, i've nearly been hit twice, miss's nearly once.
one that nearly hit my miss's i saw the dumb ass drive applying eye liner!
glad to hear all is ok!
fck! thats lucky as hell man!
did you get out and tell the guy behind u "i told u so u fcker!!!"
It's already been said, but faaaark. I'm really happy your Dad's alright, obviously could have been much worse. Poor R33 :3some:
The other driver... What an idiot, I wish people would pay attention on the roads.
That's a nasty hit.
Good thing you dad walked away OK.
As a habit a always look both ways when the light turns green especially on high speed intersections (70km/h+). It has saved me on a few occassions.
damn that's lucky...
same thing happened to me a few years ago, i slowed down for a few seconds to change a cd and when i looked up a gold falcon flew through a red @ 80+ missing my car by about 1 metre....
now i slow down and check even at green lights
glad to hear your dad is ok!
    • Try looking at Eibacb/H&R springs Thats what Gary sourced for mine.
    • Hey y'all! I'm curious about how y'all go about widebodying your cars. I noticed that when running a square setup, my front wheels are a bit more tucked in than my rear wheels. Not by much, maybe 5-10mm. This leads me to wonder - when I widebody, should I use narrower front flares and wider rear flares? I found a set of 40mm rear flares that I really like, and was thinking of pairing them with some 18mm front flares, but I don't want the car to look strange. How have others done this? Note, I'm in a sedan. Thanks!
    • And if it was anything other than an auto tranny part, it might be a problem. But seeing as all auto trannies belong in the recycling bin, it's fine.
    • I have an R32 Fenix rad. It is good.
    • All the schemas I can see, indicate your typical setup of ATF 'cooler' (read: heat exchanger) in the bottom radiator tank..ie; https://nissan.epc-data.com/stagea/wgnc34/5413-rb25det/engine/214/ ...but I can prattle on a bit here. These trannies have a thermistor in the sump ~ the TCU reads this and 1. bumps the line pressure up when the ATF is 'cold' and 2. prevents the TC lockup clutch from operating, until the ATF comes up to minimum operating temp (keeps the ATF 'churning' through the TC so it heats up quicker) -- trigger point is around 55C. In these conditions, the engine coolant temperature rises faster than the ATF temperature, and also helps heat the ATF up, which is why it's best to think of the in radiator tank setup as a heat exchanger ; the heat can flow in both directions... ...with these trannies, the 'hot' ATF comes out the front banjo bolt, flows through the cooler/heat exchanger, and returns to the box  via the rear banjo bolt. This gets a mention, due to the wildly different opinions wrt running auto trans fluid coolers ~ do you bypass the in radiator tank altogether, or put the cooler inline with the in radiator tank system...and then, do you put the additional cooler before of after the in radiator tank system?... ....fact is the nominal engine operating temp (roughly 75C), happens to be the ideal temperature for the ATF used in these trannies as well (no surprises there), so for the in radiator tank system to actually 'cool' the ATF, the ATF temp has to be hotter than that...lets say 100C -- you've got 25C of 'excess' heat, (slowly) pumping into the 75C coolant. This part of the equation changes drastically, when you've got 100C ATF flowing through an air cooled radiator ; you can move a lot more excess heat, faster ~ it is possible to cool the ATF 'too much' as it were...(climate matters a lot)... ...in an 'ideal' setup, what you're really trying to control here, is flash heating of the ATF, primarily produced by the TC interface. In a perfect world, wrt auto trans oil cooling, you want a dedicated trans cooler with builtin thermostatic valving - they exist. These should be run inline and before the in radiator tank system ~ when 'cold' the valving bypasses the fin stack, allowing the ATF to flow direct to the in radiator tank heat exchanger, so it works 'as intended' with helping heat the ATF up. When 'hot' (iirc it was 50C threshold), the valving shuts forcing the ATF through the cooler fin stack, and onto the in radiator tank heat exchanger...and you sort of think of it as a 'thermal conditioner' of sorts...ie; if you did cool your ATF down to 65C, the coolant will add a little heat, otherwise it works as intended... ...the 'hot' ATF coming from the front bango bolt, is instantiated from the TC when in use, so all/any flash heated oil, flows to the fluid-to-air cooler first, and because of the greater heat differential, you can get rid of this heat fast. Just how big (BTU/h) this cooler needs to be to effectively dissipate this TC flash heat, is the charm...too many variables to discuss here, but I just wanted to point out the nitty-gritty of automatic trans fluid coolers ~ they're a different beastie to what most ppl think of when considering an 'oil cooler'... /3.5cents
