Hey all,
R33 GTST Series 2
bought one of these the other day: http://cgi.ebay.com.au/ALLOY-INTAKE-PIPE-4...id=p3286.c0.m14
Doesn't state anywhere on the ad that its a pain in the ass to fit and that it is not a direct fit.
Hose from blow off valve and breather house have to me changed or modified!
Few pics..
Take off standard cooler piping
Remove standard intake pipe
Test fit new alloy pipe.. oh look, nothing lines up!
End up having to run new house for breather and BOV
Had to do with what we had for joining hose to alloy pipe as we couldn't get a hold of the correct size pipe for BOV plumb back into intake.
Also, had to trim about 2cm off the bottom of the pod filter other wise it wouldn't sit under the bonnet because the alloy pipe is a bit too long!!!!
In other words,
dodgey kit! Nothing lines up!!
https://www.sau.com.au/forums/topic/290463-fitted-a-alloy-intake-pipe-today/
hate to say it but this is what you get for cheap knock off items on ebay / 2nd hand traders
its probably autobahn 88 or something cheap etc
if it was a legit HKS or Trust item it would be about sub $500 and fit perfectly and mate up
but if its a knock off $80 item what can you expect?
just blank off the BOV and practice p i g e o n noise ;)
Already have.. just made up the BOV return line just so it looks like its hooked up
is that a hose holding in a hose there(big fitting nearest afm)? haha
Yes lol, BOV is blocked off anyways
Defiantly run a bigger bov return hose :P
Lol, its just so its there to make the BOV legal as you know its meant to be plumbed back. The BOV is blocked off anyways
Ah good ole ebay "direct fit" parts...
Cost you more in time than something from a well known trader if you paid initially :P
Good writeup/info on what you needed/need to do etc though for others that might get into the same predicament
someone must have stole his account
how do i know if my stock r33 pipe is closing shut running 17psi? would my knock increase??
you will lose lots of power :(
put it on a dyno and have a look while a run is being done. much easier than trying to drive with the bonnet up and someone standing on a skateboard leaning into the engine bay, LOL
There is none.
Only time you will see a 'gain' is if your stock one is sucking shut, which really isn't a gain, its just replacing a stuffed/broken part
sorry ash but i beg to differ
i made a "dose" pipe on sunday night after work and fitted it all up its 3 inch stainless steel and about 30cm long ish
the response in every gear is much better it definately had a good gain in response. the dose is not very loud either which is good too.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
