i have done this more than a few times and have never had a bad result
the biggest gain i noticed was greatly reduced lag
the reasons i did it
most of the copy plenums needed as much work, some more than the standard one
less pipe work (obvious)
tidy up the eng bay
it worked for me.
but it would be interesting to see flow bench results
then again who ever does them will do them differently
so testing 1 does not mean all r good or bad
all that being said i m using a greddy copy on the thing i m building now
but it is for height and eng bay room issues
both afr and egt's will both be directly reflective affected of the temparature in the cylinder, otherwise you wont have the detonation
does anyone have one of these floating cut and shut plenums about....i am curios to test one?
come to think of it, i have a complete spare r33 inlet, i will make one and and test it by the end of the year...i have plenty on at the moment so it will have to take a back seat for the time being
you can get detonation even with a good AFR if the cylinder temps are too high (caused by either high coolant temps or too much timing). the missus used to have a datsun stanza and when the headgasket was on it's way out and the engine temp was getting a bit high, if you drove it hard and then pulled up and turned the key off it would keep running due to detonation caused by hot spots in the cylinders. with fuel injected cars you don't get that happening because once you turn the key off everything shuts off and it can't keep sucking fuel into the engine like with a carby.
KLR33 - i will do some flow testing of it. the entry, as long as they are all cut flush at the front, will generally give the same results, give or take a few
that is usually caused by excessive timing given the engines running condition, my brothers sigma used to do the same thing.
luckily with a fuel injected car, we are able to control a lot of it under all different conditions
when u flow the modifyed one ,it would be good if u could test a standard one as well
for comparison
i and many others would be keen to see the results
not sure where u r located but if its in sydney i have standard 33 and 34 inlets u can borrow to flow
im in wollongong. i have a spare 33 which i have already done some testing with, but unfortunately the shop i done it with is no longer around and since a flow bench is like a dyno, i would prefer to do a comparison on the bench.
its on my to do list :thumbsup:
  • 1 month later...
  • 2 months later...
by modiflying ur stock intake manifold to a front facing one you will lean out ur rear cylinders. one way u can tell is take it for a drive and pull the spark plugs out and u will see the first 3 cylinders will be black from to much fuel and the rear 3 cylinders will be white from lack of fuel.
one reason i got the Plazmaman Plenum kit on my old R32. not only cut down the turbo lag i also gained 15hp.
KLR33
seeing as you have doen this mod before, what did you end up doing with the coolant/air bleed that usuallu sit near the TB?
put it in the bin
didnt run water through the TB
if i need to bleed the coolant system just undo the small hose clamp
  • 1 month later...
  • 1 month later...
    • I havent bought a manual cover for the dash yet and no cluster change, won't bother me too much, I just need to get that auto box gone, manual in! I miss my manual. 🤪. We started last weekend and managed to get the box out. Planning to start putting it in this weekend and then order a single piece tail. We were super careful to take time and not damage anything. It's my first time working under the car.  With my S15 mainly worked in the bay. This time, it was a headache because of three or four bolts only. They simply didnt want to leave thei homr and the one securing the tailshaft, another above the GB, and the one securing the lipstick was a shit. Mates mate, Davo caught fire 🤣, nearly opened his chest up with a grinder 🤦🏽‍♂️ and both mates nearly had a plate from the box land and slit their head open. Fun times. We all survived. Not the easiest working with limited access on jackstands. As I'm sure we can agree these are the memories which make us love our car. For all three of us, was an awesome weekend and Sunday 3.30am before tools down was a fantastic effort. I need to upload pics, but looks like it needs to be via Url now. We used to be able to just upload pics back in the day. It's been that long! 🤪 Im currently spraying rustoleum under body, not because it's rusted. It's super clean, but just so it's protected for the next 10 years. There was a few surface rust spots. Which pretty much wiped off with a 3M scourer.  Really impressed with how well the previous owner maintained it. Bank account went down so quick! Service, then GB - managed to get a spanking new 34 genuine box from Nissan. All the rest of the conversion parts from Kudos.  Went with a Nismo short shifter. New pedals and Exedy Clutch and FW. Ordered the Prp Rear Main Retainer kit which should arrive Friday and my first engine mod part just like I did with my S15 will be the Tomei Expreme Turbo Outlet. Already on order. It'll likely sleep next to me on a pillow during the coming months. 🥰 Last build was on my JET200GT profile and on SAU and Hardtuned I had documented the build. Planning to try to do that again. Brands feel scarce now. Wish we still had ARC and Apexi parts readily available. Exhaust - need some advice on this. I had an Apexi exhaust on the S15 and loved the tone. My mate had a HKS HP Silent on his 33 and suggested I go with that to avoid drone. I can't remember hearing an RB25DET running that so will likely need to wait for a meet or something to hear it.  Not after big power, just enjoy building it, and drivability with minimal negative attention.
    • Have a chat with Ben at Moore Performance or Jesse at JS Performance.
    • Thanks both. All good advice. Reminds me of drilling through stone wall for drainage pipe 😬 I'll let you know how I get on if I still have use of my hands afterwards 😅
    • Finally got shipping number for the intake and throttle body, shipped by UPS, so "should" be in my hands sometime next week, fingers fracking crossed
    • I'm so far behind in the jobs I have to do at both work and home (including car) that I have become immortal. There's simply no way that I can die now.
