Hows it going
For sale
Unknown brand t04e brand new has garret model number but isnt garrett $300 is ""skyline flange""
Tial 38mm external wastegate $100
~~ Or 350 For both wanted more power but have been told on my rb20 will be lagging till about 4,600 - 5000 would pull some awesome numbers for drag or dyno queen !!!
Suspension full set of lowered pedders spring and shocker assemblies to fit r32 400$ in really good condition !!!
Wanted rb20det head , worked already with cams ect have a blown head gasket so lookign for a head instead of rebuilding mine would be keen on swapping some of this gear + cash if anyones interested
Wanted a turbo a bit bigger than my highflowed r33 turbo that i have on at the moment for a bit more power nothign as laggy as the t04e tho!!!
I am in SA btw north eastern suburbs near ttp
Would also be looking at eoi sale or swap on my r34 gtt rims 17 inch with 90% tread lookign for 18 inch rims gold or black or whatever
all enquiries via text or call cheers Dino 0422176914
https://www.sau.com.au/forums/topic/290494-for-sale-swap-sa-wanted/
    • Stock equivalent turbo replacement is a bit of a nightmare. The old Hitachi ceramic things were pretty good for their time, but they have primitive, vintage aerodynamics. The only thing they have going for them is a light turbine**, and there are plenty of other light turbine options these days, in both materials and CNC manufacturing methods. So, the old stocker makes absolutely no power at all compared to its physical size and its (not very low) boost threshold and response. ** and the ONLY thing that was good about the ceramic turbine was that it was light. In all other respects it is a nightmare. To get a turbo that is anywhere near equivalent in terms of power capacity (ie, to avoid it being "bigger" and needing tuning/fuelling/etc) you have to physically downsize. And that is not a "stockish" replacement. Doesn't just fit where the old one did. At least a frame size down, probably need a new dump, probably need new inlet and outlet piping made on the compressor side, new hose connections as D said above. I say, if you have to suffer that much work, you might as well do the same work to fit an even bigger (than stock) turbo, have more power (and hence have to do injectors, ECU, etc), and love life, instead of suffering with stock power levels. Or, you get a light highflow from someone like Hypergear. A highflow that has not been pushed too far from stock. There are still modification consequences here though. HG's cores are smaller than the massive Hitachi core, so it is shorter, moves the compressor housing backwards and requires mods to the air side piping. Plus new hoses. Looks stock, mostly fits where the stock one did (with the previous caveats mentioned), makes a bit more power but can be run at stock boost levels and not cause too many ECU problems. But, seriously. It's 2024. Like - 25 years since the R33 came out. It's time to put an ECU in it. I Nistuned my car (on RB20 ECU then later again on the Neo ECU) and it was the single best thing possible for minimal money. Dial out the R&R bullshit, fix up the fuelling and timing to make it more efficient for normal driving (cut fuel consumption by >10%). Nistune is not an option for you unless you change the ECU, so you might as well just do a standalone. it will be worth it. And then you can tune it up to the limits of the injectors and AFM, which is pushing 200rwkW and enjoy some actual squirt, instead of the lazy barge-like motion you get from a stock engine, turbo and management.
    • He can't post pics until he's at 10 post count.
    • Welcome James.....will be interesting to see how much fun there is in the project. .....where's the pics?
    • Your profile doesn't say where you are, but you can get your current turbo rebuilt by any competent turbo shop, places like Precision Turbos or GCG They can replace the core with a modern ball bearing unit and should be able to source same or slightly larger wheels to fit in you housing. Note if you change the core you may need new oil and water lines too
