Hi guys,
On a general R34 manual, it has the instructions for starting the Engine...
One of the steps is this:
Push the accelerator pedal half-way to the floor and hold it there while starting the engine
Is this step really necessary?
What could happen if you don't?
Edited by Elbbie
https://www.sau.com.au/forums/topic/290502-starting-the-engine/
My reccommendation, is that unless you're having troubles starting the engine without that step, DON'T do it.
When an engine first kicks over, there is no oil pressure. Giving it some throttle will probably cause it to rev a little more than necessary, in turn causing that little bit more wear on various internals.
While it's been cold here in Canberra, I've had the occasional occurance of my engine coming very close to stalling immediately after starting it, simply tapping the throttle gets the revs back up and it will idle correctly.
Hope that helps
Hey Trozzle, could I ask what you're Idle revs are on Cold starts? Also what are the revs for stall?
I've got an Auto and I have noticed that the revs never fall below 1,000 even on idle, which is curious because our other cars, idle is around 700-800
Is this normal for the car?
it should idle a bit lower that that. i would suggest adjusting the idle screw to lower the idle. this is best done in base idle mode as if you just do it with the engine running the ecu will try and adjust the idle to where it was. i think that for the r34 you have to get the car up to temp then turn it off, disconnect the TPS and then start the car. i'm not 100% sure that is the way though, but i know it is for the pulsar which uses the same consult system. but i just use a consult cable and a consult program to lock it into base idle mode
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
