I did a shed clean out last weekend
From memory i have:
R32 PS Pump $120 (on hold)
R32 Complete wiring loom $180
R32 Computer $50
R32 Ignitor $80
R32 Coil pack cover $50
R32 Standard fuel rail modified with center feed return (currently has a speedflow block off) good for your big power RB20 or R32 RB25DE Head - $80
R32 Injector plugs (I may be able to use these) $15
Sard Injector plugs $20
Set of average coilpacks $30
Set of perfect working coilpacks (will be for sale after I tune) $150
R32 Coil pack loom in good condition $35
R32 Air Conditioning condensor + some lines $150
RB30 Sump Good condition $100
R33 Standard cooler pipes $20
R33 Stock Fuel Regulator $20
R33 Standard crossover pipe and BOV $40
R33 Standard intake pipe $30
R33 Steering Rack suit rebuild $30
R33 Alternator $150 (on hold)
R33 Carbon Canister $30
R33 Standard Oil Cooler that bolts to the block $50
R33 Dipstick and guide $20
R33 Windscreen washer bottle $30
R33 Aftermarket Blue silicone Top radiator hose $40
R33 Single Din coin compartment holder thing (under the Head unit) $20
Few bits of 3" Blue Silicone $10 each
Blue silicone RB25 Throttle body -> 3" Adapter brand new - $20
Tons of hoses plugs and brackets i cant remember where they all go...
https://www.sau.com.au/forums/topic/290529-random-r32-and-r33-parts/
no because the whole sentence reads "R32 Standard fuel rail modified with center feed return (currently has a speedflow block off) good for your big power RB20 or R32 RB25DE Head - $80"
  • 1 month later...
  • 3 weeks later...
  • 4 weeks later...
  • 4 weeks later...
    • Gday, Due to not finding much up to date info on this topic I thought I'd make a thread to get peoples latest opinions/recommendations. Background info -  I've got a S1.5 R33 GTST as a fun project car, mainly for street use and occasional drag strip, apart from all the cosmetic things I'll be doing a full rebuild of the engine with forged internals. Since it'll be getting new cams (kelford) and springs to match I thought I might as well get new lifters and valves while I'm at it, the dash says 160k KMs but the engine seems pretty tired, compression measures about 130psi across all cylinders so I'd like to freshen everything up. This is where I'm tempted to just fork out the extra and go solid lifters while it's all apart, aiming for 400-450kw atw with a flex tune. Assuming all supporting mods (oiling, fuel and all bolt ons) with a lightly ported head and turbo to match (yet to make a decision possibly gtx3582r or similar from Hypergear) I've seen the Tomei kits with just the buckets getting around, Supertech sells most things - Supertech High Performance Cam Followers | Trusted Racing Cam Followers Questions -  Has anyone found the Hydraulic lifters to limit them at this power level? Is it usually found that you can just clean the stock lifters and find they work fine?  Does going solid lifters save any headaches/issues with hydraulic lifters in the future? Any recommendations on other things that will need to be replaced, I know I'll need to get the solid profile cams but can you use the same type of valves and springs/retainers and is it recommended to change the guides and stem seals?    Summary -  Basically looking for pros/cons and wanna know if I'll actually need the extra RPMs from solid lifters or it'll just be bragging rights to say it ReVs OvEr 8000 Cheers
    • Ha ha ha, this stuff they had was installing Toshiba PLCs that were made some time in the 1990s, and they were replacing GEM80 PLCs. To let those two talk (staged upgrade along a ~1.2km long building that was split into 4 sections), was a bunch of WinXP machines running Java gateways... There was no way to put something like ProfiSafe in... Most of the HMI machines were WinXP, with Java program, with a custom button board emulating a keyboard... About the only buttons in the operator stations that went direct to the PLCs was the eStop. There was some interesting design stuff in that place...
    • Stock bypass valves are good for plenty of boost.
    • Check for fuel flow out of the outlet end of the rail. Check for spark. Try to start with aerostart (or pressure can brake cleaner or similar solvent in a car) prayed in through TB. If you have fuel and you have spark and it will fire on substitute fuel, then seriously suspect that E85 sitting for ages in your fuel system has destroyed something and put it in your injectors.
    • Nissan stock oil pressure is typically about 1 bar at 1000 rpm plus about 1 bar per thousand revs on top.
