I did a shed clean out last weekend
From memory i have:
R32 PS Pump $120 (on hold)
R32 Complete wiring loom $180
R32 Computer $50
R32 Ignitor $80
R32 Coil pack cover $50
R32 Standard fuel rail modified with center feed return (currently has a speedflow block off) good for your big power RB20 or R32 RB25DE Head - $80
R32 Injector plugs (I may be able to use these) $15
Sard Injector plugs $20
Set of average coilpacks $30
Set of perfect working coilpacks (will be for sale after I tune) $150
R32 Coil pack loom in good condition $35
R32 Air Conditioning condensor + some lines $150
RB30 Sump Good condition $100
R33 Standard cooler pipes $20
R33 Stock Fuel Regulator $20
R33 Standard crossover pipe and BOV $40
R33 Standard intake pipe $30
R33 Steering Rack suit rebuild $30
R33 Alternator $150 (on hold)
R33 Carbon Canister $30
R33 Standard Oil Cooler that bolts to the block $50
R33 Dipstick and guide $20
R33 Windscreen washer bottle $30
R33 Aftermarket Blue silicone Top radiator hose $40
R33 Single Din coin compartment holder thing (under the Head unit) $20
Few bits of 3" Blue Silicone $10 each
Blue silicone RB25 Throttle body -> 3" Adapter brand new - $20
Tons of hoses plugs and brackets i cant remember where they all go...
https://www.sau.com.au/forums/topic/290529-random-r32-and-r33-parts/
no because the whole sentence reads "R32 Standard fuel rail modified with center feed return (currently has a speedflow block off) good for your big power RB20 or R32 RB25DE Head - $80"
  • 1 month later...
  • 3 weeks later...
  • 4 weeks later...
  • 4 weeks later...
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
