Hi there, Has any one programmed their own copgy back EPROM's and then soldered them back for cars such as Nissan Pulsar 90 and VN 88 Group A Aero.?? Apparently when they are tuned correctly you gain more power than the chips you can buy for power gains..
Im trying to find a walk through or someone with some knowledge on self tuning and programming stock ECU's..
If i can find a detailed walk through in regards to removing, programming and can find a decent base tune map i might have to invest in an EPROM programming kit from dick smith for $100... Maybe that degree in Computer Systems Engineering will come in handy after all..
It should be an interesting learning experience self programming these EPROM memory chips and finding the correct ratios and timing positions... I could imagine it would be quite straight forward once the existing assembly language can be accessed and altered and i would be changing around a few array values which would correspond to the throttle mapping positions for the A/F ratios.
If someone could tell me where these EPROMS are available in Australia and what type they are...(I think that the 1.8 litre 90 pulsar and the VN commodores from that era have the same type of EPROM and can be replaced with the Holden Camira type EPROM which is fully reprogrammable and i beleive is a type 808 27C256 -- dont quote me on those numbers... If someone with some tuning knowledge could back that up for me that would be very much appreciated as i would not mind buying a coupleof chips and having a play around to get some more power from my rides..
REgards... Chris
Ummm... Yeah...
A guy called Ken (or was it Kevin?) Young did this ages ago. His program is called kalmaker and can completely and utterly reprogram any of the Australian GM-Delco computers. Google 'Kalmaker'.
Alternatively the DIY-EFI crowd (Which can also be googled) can help you out. I'm subscribed to their mailing list, but most of the stuff goes over my head, I'm more interested in the mechanical side of their problems (Turbocharged 350 chevs using a holley 4 plate throttle body and a re-programmed computer that came off a 6 cylinder car are quite interesting things to read about).
    • The car revs up through the gears much better/faster now, and fuel consumption doesn't really seem to have be affected either on a Hwy cruise, which wasn't expected  The FAB9 intake manifold has been problematic sourcing though, I've contacted Plasmaman to ask about their intake, which you can get different runner lengths spec'd, and, their different options for throttle bodies  The only real physical drawback with the Plasmaman intake is how to connect it to my current OEM style airbox, as FAB9 make a OEM style back half of the airbox to suit the larger diameter throttle body, and all that is required is a 30°bend silicone pipe to mate the throttle body to the airbox Car also goes in for some exhaust work in a week or so to fit the biggest resonator they can fit clearance wise in the front pipe to help remove some of the drone, there isn't alot of realestate under there, a rough guesstimation is it will only be about 3-400mm long and maybe 90-100mm diameter, and with a 60mm exhaust that doesn't leave alot of space for the internal volume of the resonator to do its thing I'm thinking I may need to bin the "high flow" 100 cell cat for something a bit more substantial, yeah, and restrictive, like a 200-400 cell, to help, but, I have ample room for a really large bodied cat to replace the current one which has around a 4" diameter body I may look around in the recycling bins and see if I can find a massive newish cat that was "replaced" with some new full exhaust system that the local exhaust shop in Western Sydney is doing
    • Hahah look at that smile 😂 Just like those ones on IG where they compare the husband in family photos vs husband going fishing lol. I don't think I'll participate this time, clutch isn't in and also the last time I went there were too many numpties on the cruise sessions. Nearly caused a few accidents holding up people and a few guys initiating massive kerb to kerb drifts with heaps of cars right behind them. Not to mention, there were guys on the track session using it as a power cruise session.
    • Is there an actual website thingie for peoples who don't have Facebooks? Cheers
    • All Jap Day is coming up again! 13th of July this year. Are you going? Tickets go on sale on Wednesday 6pm. Please let Quang know as well. https://m.facebook.com/photo.php?fbid=1163155775853542   I still get shit from my wife for this photo because it is the happiest she has ever seen me. And it's not with her, it's in someone else's car.   Quang's EVO is sick, but that rotary wagon flying past was absolutely bonkers.
