As the title says i have the black box and the software but im seeing if any1 has bought the cable from the box to the laptop that has worked properely with the software and pfc. if you have can you post up the brand and model of the adaptor that you bought. or am i beter of just buying the 1 from the datalogit site. Thanks in advance and yes i have searched but couldnt find the info i need
https://www.sau.com.au/forums/topic/290562-fc-datalogit-cable/
i've used the one on the datalogit site and a $2 ebay adaptor with my datalogit, both work fine altho the ebay one has dropped out before when using it on my wideband controller. if your not in any hurry for the insignifigant money i'd try an ebay one before spending $50+ on a proper one
I wanted to cover all the bases so I bought my Datalogit with their USB converter cable , and through E Bay a Dell Latitude D610M for under $400 . It has a real serial port and it's now set up to dual boot Win XP or Windows 7 .
The Tech Edge WB3A2 I have can use either as well , serial via its RJ45 socket or USB through a std square socket . I actually screwed up here because the Tech Edge uses its RJ45 socket to plug the LCD display in , they kindly sent me an RJ45 splitter with steering diodes in it so I can connect the display and serial cable through the one socket on the controller box .
Serial comms work quite reliably its just that Lap Top manufacturers have tried hard to get rid of the serial interface because most home users don't need it . Universal Serial Bus was never quite as universal as is should be and not surprisingly a lot of scientific test equipment demands a serial interface .
In the end I think most people buy an older lap top with a real serial port and use that for car stuff .
I particularly like the Dell D610M because its fine to surf the net or whatever and can talk to your Datalogit through a cheap reliable easy to get serial cable .
Other than that get the Datalogit people to send you their USB converter cable .
A .
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
