Just to chime in that there is another factory super turbo.
Golf GT :Dhttp://www.webwombat.com.au/motoring/news_...f-gt-review.htm
Love these cars and enjoyed the episode from mighty mods :).
  • Replies 80
  • 6 months later...
an update.....
we (well maybe I) decided it could live with some more turbo lag with the SC to look after things down low.
So it is at Hills Motorsport getting a GTR T28 turbo and new manifold put on.
At the same time it became clear that it has a fair bit of blow by already, so we have order a set of forged bottom end bits from some wierd little japanese car guy in hokaido that used to race them. and a catch can to keep it sort of under control in the meantime.
yep it says "an intake restrictor". that got a bit tricky for GTR with 2 intakes but the mighty march only has 1 intake.
I figure the only chance for a turbo car in IPRA is either spend way more than 1 can afford, or something light and small enough that the restrictor won't limit power. No chance of 900cc making make 350hp so I am safe.
oh yeah, just reminded me, the GTRs or and other car with 2 intakes need to run 2 26mm restrictors.
lol 7 bar sounds nice. might have a bit of trouble holding the head on.
in unrelated news....I saw pics of the super turbo's older brother today....its a 1985 K10 March Turbo. Love the dash and steering wheel...
they dont have any trouble holding the heads down, the problem is stopping the block splitting in half and leaving the crank + pistons down the bottom and the head/cyls elsewhere. :/
Just reading the regs on all of this duncan, I think you'll be stuck with two restrictors...
For vehicles utilising a turbine type compressor, the restrictor must be fitted as per diagram 254.4 (see “Rally/Road” in the CAMS Manual of Motor Sport), save that the maximum internal diameter of the air intake into the compressor is 36.0mm where a single supercharging device is fitted, or 27.0mm where two devices are fitted.
PS: I haven't finished reading ths damn 3 million page long manual, so there may be something I've missed...
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
