OK!
I have made up my mind and will be going with the Haltech plug n play ecu especially now that the ecu's and software have been updated and are even better than before!
Now the question is:
Who in the south-east QLD area is best for tuning the Haltech/RB25 combo?
  • Replies 41
i would speak to scott @ haltech, they can reccomend someone who knows thier product the best, not someone who thinks they are the best :D .
HAHA! Yea cheers aye! I know what you mean!
I wish I was down there so you could tune it for me as I have been observing your vast knowledge for some time now.
How about we all stop high-jacking the thread and get back on topic.
And as for the EMS comment, please explain how and why you justify this opinion as I can’t see that decision being logical at all for my intended purpose especially considering its not plug 'n' play?
How about Pro Torque performance?
They apparently deal and tune haltech however I have never really heard of them.
Can anyone recommend them?
  • 2 months later...
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
