OK....after much frustration, I got the top half off...now, that f**king lower half...namely that 7mm bolt, on the lower row, close to the firewall (so, from the firewall in, its the second bolt, or the first bolt on the bottom row)....
I've tried many naughty yoga positions with the socket, and couldn't quiet get it, I even tried from out near the strut tower, using 3x extension bars...still not luck....should I be using a ring set or is there a trick to this ? What angle am I supposed to break my wrist to get into
Once its off, massive clean and going black to match the upper half of the manifold, looks sexy-as, I'll post a pic....once its done, but need help first :3some:
Edited by Nic_A31
https://www.sau.com.au/forums/topic/290600-removing-intake-manifold/
Uni joints are your friend. Perfect for undoing nuts and bolts around corners.
Ive pulled off my manifold 4 times now, but I kept the two halfs together every single time. It also helps if you have someone under the car guiding the socket or spanner onto the bolt.
You've got some unusual skills mate :thumbsup:
Cheers, bought myself another uni joint this arvo (hopefully wont lose this one), and got it off, no probs - didnt think to try one because I figured they're too big.
The engine bay is looking very naughty now - have to trace and cut some gaskets, replace the brake booster, paint the firewall, and slap it all back together, and then expect some masturbation material.
OK, took a very quick photo tonight.
Im also using my engine bay as storage, same as the interior so dont mind all the other shit in the photo.
It looked sexier in my head, think it looks too much like an RB25 copy-cat, but eh, can always sand back and respray.
Opinions ??
Yeah thats what I reckon. I am painting the engine bay black though...a matt black, not a gloss black, all the shit in the photo has an undercoat of a dark grey kind of finish..it looks black for now but will probably show up with a dark background - see what happens. I'm not keen on having an engine bay full of colors, bling and a rainbow...it looks like shit and all the more reason to expect a canary yellow to finish the color wheel.
  • 4 years later...
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
