OK....after much frustration, I got the top half off...now, that f**king lower half...namely that 7mm bolt, on the lower row, close to the firewall (so, from the firewall in, its the second bolt, or the first bolt on the bottom row)....
I've tried many naughty yoga positions with the socket, and couldn't quiet get it, I even tried from out near the strut tower, using 3x extension bars...still not luck....should I be using a ring set or is there a trick to this ? What angle am I supposed to break my wrist to get into
Once its off, massive clean and going black to match the upper half of the manifold, looks sexy-as, I'll post a pic....once its done, but need help first :3some:
Edited by Nic_A31
https://www.sau.com.au/forums/topic/290600-removing-intake-manifold/
Uni joints are your friend. Perfect for undoing nuts and bolts around corners.
Ive pulled off my manifold 4 times now, but I kept the two halfs together every single time. It also helps if you have someone under the car guiding the socket or spanner onto the bolt.
You've got some unusual skills mate :thumbsup:
Cheers, bought myself another uni joint this arvo (hopefully wont lose this one), and got it off, no probs - didnt think to try one because I figured they're too big.
The engine bay is looking very naughty now - have to trace and cut some gaskets, replace the brake booster, paint the firewall, and slap it all back together, and then expect some masturbation material.
OK, took a very quick photo tonight.
Im also using my engine bay as storage, same as the interior so dont mind all the other shit in the photo.
It looked sexier in my head, think it looks too much like an RB25 copy-cat, but eh, can always sand back and respray.
Opinions ??
Yeah thats what I reckon. I am painting the engine bay black though...a matt black, not a gloss black, all the shit in the photo has an undercoat of a dark grey kind of finish..it looks black for now but will probably show up with a dark background - see what happens. I'm not keen on having an engine bay full of colors, bling and a rainbow...it looks like shit and all the more reason to expect a canary yellow to finish the color wheel.
  • 4 years later...
    • Took it for a drive to do some logs, I’m pretty sure my voltage issues and electrical noise issues are gone, I’ve sent a log to Adam and am waiting to hear back with confirmation  att.K23U9eHyiEJxixH6y1__GQfuqK0EgIoDgQFTs9G8x_w.mp4   idle video from that day just because
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!)     I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding).   I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springs  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
    • Ok got some old tyres for you guys...my car has been sitting around un-driven for about 6 years now. I had it on the original rims with the shitty compliance tyres it got it with back in 2006, which were manufactured in 2004... Sidewalls eventually rotted and split open, obviously no air in them and the rims were holding the car up. Just swapped them with some 17" Work rims and tyres which are probably 10+ years old too but at least holding air
