Just came across this force flow superchargers. US made and seen some youtube comparison with other China knock offs.
any one actually used it? retailed around from $500~ $1000 each
http://www.force-flow.com/
Edited by kwickr33
https://www.sau.com.au/forums/topic/290602-force-flow-electric-superchargers/
People say that it is a waste of time. I was interested in doing it a while back due to being on P's and having restrictions to only driving n/a. Was going to fit a turbine into the intake piping, 3 inch or so for the stealth look. But the argument behind it was that it runs out of puff and will start to be restrictive to the engine at the mid / top end.
Here is a link from a properly done one and what was achieved:
http://www.turbomagazine.com/tech/0406tur_...rger/index.html
And a quick link to a pic of the system, it's not just a simple fan:
I still think that there's something behind the turbine in the intake piping though... brushless motors are damn fast and incredibly efficient. If you could make it flow really well it could help with bottom end torque and not restrict the upper end. Probably not worth it though. Only be useful for lightly tuned engines or stealth n/a for p drivers.
Hope this helps
~Danz
they blew up the test car due to leaning out. not the best testing procedure.
look at the size if it its a pretty big unit. by the time you fitted one of these and 3 batteries and wiring, piping, new bypass valve ect it would cost more than a goot turbo setup.
Hope this helps
~Danz
In regards to the article - I'm approaching this quite cynical. If the technology is good, car manufacturers would have jumped on the bandwagon around 10 years ago.
"Maybe good" strictly for low end application for people after high torque at low RPMs or people wanting an NA+T style setup. Don't think it will be used to make big power... but who knows what the future may bring.
Clear advantage with this system would be zero lag as the supercharger will be independent on engine speed and you can mount it in almost any direction.
Disadvantage - it would be heavy, especially since you will need extra wiring battery and anything else required for such a power hungry device.
Possibly system could be made lighter by using lighter metals, faster/lighter motors, battery technology might improve further and regenerative braking could be used to help charge the batteries faster... but then, again with all that said and done... It would have been easier to go straight to a hybrid (petrol+electric aka Prius) setup and not have the electric supercharger.... as hybrids have pretty good torque from low RPMs.
I'd imagine this whole electric supercharger idea is more of a retro fit to current vehicles that need the extra torque, slight power increase and possibly economy - but no means the future of forced induction.
a different way to do it....
you purchase a "smog pump" from the USA
hook that up to air-cond. pump so it's spinning and forcing air (~800cfm)
run this unit in the intake and you'd notice a difference
a little trick to force-feed air for motorbikes...... same principle for RB engines.
I'm thinking along the same lines, low rpm boost.
But what if it was only used until the turbo comes in, somewhat like the new vw TSI engine which has both a supercharger and turbocharger, once boost goes past a specific amount, the clutch for the supercharger disengages and the turbo is solely run.
In the same way, an electric supercharger could be used, say it gives it boost until the turbo spools up enough. And in terms of choking the airflow, it could run a bypass valve / pipe which will flow the air around the elec supercharger.
I've never actually heard about this before... so you sacrifice your a/c for performance, it pumps the air into the exhaust manifold... very interesting. This would only benefit n/a engines I would imagine?
I noticed when reading up on it that it said it lets the fuel burn for a longer period of time resulting in less restriction of flow. Does a stock engine normally have flames in the exhaust? I mean I know you can do stuff with timing and cutting ingnition in order to get flames out the end of the exhaust, but I didn't realize that there was actual flames outside the combustion area of an engine.
What kind of improvement would this modification give you, would it be a better alternative than the elec supercharger in terms of power, weight, and cost?
And are a/c units made to have a constant high duty - will it fail over time?
tried it on my mate's gf's Prelude Si, non VTEC
Made a bit of a difference, nothing extreme, he wasted like $600 on that forceflow thing, drains shit loads of current on powering up.
Not a good investment, but it did make some power, I'm imaging serious lean-outs too...
Would be good connected to a SAFC or similar.
I could really see this going somewhere though, if it was only used to 'giddy up' the engine through the low rpm until the turbo charger has enough momentum to take over. Then to stop it from choking the system, go around it via a bypass valve or something.
Definitely shouldn't be used as a stand alone forced induction. That way it doesn't use a stupid amount of power from the batt either.
On that note, why do people put more batteries into the car in order to compensate for the elec supercharger. Wouldn't you be improving the alternator, not the batteries? I mean it's like having a 100L fuel tank but never actually filling it up that much as it gets used quicker than it can store it.
    • A few things that seem a bit off here. - why is there 2 BOV’s?  - the turbo smart BOV on the compressor housing, is it turned up ALL the way? I have seen this become an issue on old man Pete’s car. It would push open and recirc, turbo speed would rise and the boost pressure would do weird things. - stock head? Does that include springs? - tried a different MAC valve? Is it plumbed correctly?
    • Photo of manifold showing gate location? I mean, it's 6Boost, so we probably shouldn't be worrying, but always wroth knowing what the layout is. Plumbed back to atmosphere? Or into the dump?
    • Yes correct. Also, I'd avoid applying it to soft paint (however I doubt you'll ever have to deal with it in practice). So any paint that hasn't fully hardened, could be a 1k paint that never fully hardened or it could be a 2k paint that was laid down thick and hasn't yet fully hardened.
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
