  • Replies 41
hey Steve, on my 34 the car misses on idle when the gap is 0.8 with the copper plugs .. 1.0 gap and no worries.
Hamish, I actually WANT to use a 1.1 gap for better combustion/power/fuel eco .. :P One of the reasons I got the splitfires.
most people gap to 0.8 with splitfires anyway....
TBH it might work @ 1.1 but with that plenum in the way i aint gonna bother to find out :P
heat range 7 seems to be the go too for 200+rwkw stenve... although 6 is quite popular and works on many a gtt/gtst
did it miss instantly? or could you have fouled them?
I've had heat range 6 and 7 in my 190rwkw R34 .. 7's give a slightly better fuel eco I think but apart from that they're both about the same. Unigroup were encouraging me to stick with 7s at this power level and I think they know what they are talking about. I'd give the 6s a miss unless your skyline is completely stock.
Johnny which ones are you talking about, the BCPR7ES-11's ?
found the BCPR7ES-11's at local repco just down the road .. woops, shoulda checked there first :whistling: $31 for 6, all goodah
Told you so :D
They're quite easy to get a hand on!
From memory it appeared to miss instantly (well about 30seconds or so after i started it), but i cant be sure. car isn't tuned yet so its possible i fouled them. (could be a loose loom connection, badly seated coilpack etc, bit of dirt or something as well)
I thought about gapping them back up to 1.0mm, but its odd that it didn't miss with the 7 heat range plugs at a 0.7mm gap :S i was under the impression the smaller the gap the worse the idle?
just called the local repco and ordered in the BCPR7ES-11's for me.
so tomorrow i'll throw them in at a 0.8mm gap i guess? what do you guys reckon? (running splitfires)
dont really feel like taking them in and out if it doesn't work haha. is it better to run them at 1.1mm gap if i can?
tony (munkyboy) runs the 7's at 1.1mm (i think) and he hasn't had an issue, but he has only just gotten some yellow jacket coils or whatever they are called
yeah 1.1mm with new coilpacks. but thats only at 13psi. i think i'll be going to 0.9mm for 16-18psi, and hope it holds up on the dyno.
looks like ive joined the 1.1mm club
just finished up and took it for a spin.
put it the bcpr7es-11's checked all the gaps, they were at 1.1mm then didn't touch them
took out the bcpr6es put in new plugs carefully hooked everything up and tada!
no more miss at idle, car seems to pull a lot easier, seemed a bit more powerful (probs just cause i was breaking traction on the wet roads all the time haha)
im running 12psi max. usually peaks about 11.5psi and no sign of a miss anywhere.
so there ya go if you are running splitfires at max 12psi, in "theory" you should be able to run 1.1mm gaps
how'd you go wacky dee?
just waiting for my splitfires to arrive and a date with unigroup ... I'm gonna do the same as you (same boost as well..11.5psi sometimes 12max depending on weather I guess) Good to hear you're not having any issues.
What did you use to check the gap on the new plugs? I checked with repco and they had those feelers but max .8mm or so (5 different kinds all maxed out at under 1mm)
lol. you add the different thicknesses together to make the amount you want. ie. 0.8 with a 0.3 or as close as you can. put them together, and check the gap.
yeah, what he said.
Dont worry i looked at it for a minute and went "wtf?"
Has anyone had issues with 7's fouling for normal street use?
I run BKR6E at 1.1mm on street (95%) and 7's at .9mm when it gets the boot in - 250rwkw+. I have remote mounted coils so swapping out plugs is a 5 minute job.
Is the OEM plug the same height as the BCP or the BKR? Maybe the BCP are actually too tall and put stress on the coils?
well im having the same issue as Stenve.....put in bcpr6es gapped to .8mm and now it misses.....at the start it would only miss when it warmed up...but now it misses from the time i start the car....
i have a little over 200kw s2 r33....have jjr coils....should i be running bigger or smaller gap??? and should I be using the 7???
thanks!!
6s will do the job ..but 7s are probably better for > 200rwkw and put the gap back up to .9 or 1mm and you should be ok. If that doesn't fix it, one or more of your jjr coils are dodgy.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
