Hi guys. Have lowered the Stagea and after a bit inside rear tyre wear I installed adjustable camber arms. I took it in to have the alignment done and they couldn't get the toe AND the camber to a reasonable point. I've deduced that I need adjustable toe control arms as well. Which arm do I need to replace in the photos below? Thanks.
Yes its the one in the 2nd picture.
You will only need toe and camber arms.
Yes they are the same popular toe arm as the other nissans.
Ryan from ISCperformance (sight sponsor) sells them fairly well priced :whistling:
Ryan from ISCperformance (sight sponsor) sells them fairly well priced :dry:
Cheers for the info but i'm currently in the UK. These have arrived from Driftworks. Just need it to stop raining now.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
