hey all,
i recently bought my R34 GT25...has factory xenon headlights, but the xenon bulbs were changed during compliance, the xenon headlights are still there, just the bulb appears to be changed, got a couple of questions.
1) is there anyway to get hold of stock r34 xenon bulbs?
2) if not, how much are bulbs which have the same colour light as the stock xenons?
Cheers
https://www.sau.com.au/forums/topic/290630-xenon-lights/
im not to sure what bulb is there atm. ill check after im home from work.
in regards to the ballast question, im not to sure what you mean? could you please go into detail? sorry for being a pain :P
Cheers
https://www.sau.com.au/forums/topic/290630-xenon-lights/#findComment-4862392
hid kit is easier to install.. as they installed a "spacer ring" in your light to hod the h1 bulb.. and hid kit works well (NYTSKY) can prob still supply you a kit.. but some think you get more glare from the HID as it was designed for the xenon.. myself am more than happy with the HID kit
https://www.sau.com.au/forums/topic/290630-xenon-lights/#findComment-4862444
another one for a HID kit from NYTSKY, got an 8000k H1 Bosch HID kit through him for my 34, works a treat and easy to install
how does 8000k look...thats what i would want but ive heard they are too blue and attract a lot of unwanted attention??
got any pics by any chance of how they look @ night on your 34?
https://www.sau.com.au/forums/topic/290630-xenon-lights/#findComment-4862579
if i get the chance ill take some for you tonight, the bosch 8000k kit i got from NYTSKY isnt too blue at all, and gives a nice spread of light, and i can't say that i have ever been high beamed or anything for them being too bright either
https://www.sau.com.au/forums/topic/290630-xenon-lights/#findComment-4862728
stock xenon bulbs are 4300k ... I put 6000k on mine as they have a slight blue tinge. 8000k is noticably bluish it's just that people get used to them and think they're not
not true, it varies with the manufacturer, i have seen some 8000k kits that are ridiculously blue, as for mine, i have asked people who have been driving in front of me, and i have looked from a distance myself, and they only have a tinge of blue.
https://www.sau.com.au/forums/topic/290630-xenon-lights/#findComment-4863307
+1, wanted to change mine to HID too but don't want the trouble of getting defected.
Yea, my mate has a full stock R34 with factory HID, on P's. He got pulled over by a cop one day and got questioned about his HID, he's like they are stock and came from factory. But the cop said to him, it doesn't matter, they aren't even meant to be on there, as they aren't self-adjusting.
So at the end, he got dicked for it lol.
https://www.sau.com.au/forums/topic/290630-xenon-lights/#findComment-4869989
Not sure what you mean by self adjusting, but they can be dipped with the factory in car dial thingy near the coin slot, that said, i am aware that they are still illegal...
https://www.sau.com.au/forums/topic/290630-xenon-lights/#findComment-4870171
With the current volume of new cars with HID standard, it's not really being targeted anymore. Too hard basket.
Also HIDs are never 100% the correct colour when you first put them in, they change over about 300-500hours to get to the final temp colour they were advertised as.
https://www.sau.com.au/forums/topic/290630-xenon-lights/#findComment-4870196
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
