i have the nismo R tune intake, which puts the pod right at the bottom where the cold air can get into it.
my worry is water lock. now i wont be driving through rivers, but puddles come up on the road and i cant do anything but drive through them. So whats the go with water lock. if 10ml of water gets in is the engine toast? or will the filter block out a fair bit and as long as i dont drive through massive deep puddles i should be ok. for reference, the pod is just above where the black grill/guards are on the front.
is it worth the risk? am i over reacting? do alot of cars have their intakes low and they have no worries?
Also, the R tune has a water lock bypass thingy, but as far as i can tell, it works if the pod is submersed and doesnt suck, it kind of opens up a to let air in and the water is therefore not sucked into the engine under extreme pressure.
What are your thoughts???
https://www.sau.com.au/forums/topic/290663-water-lock-and-cold-air-intakes/
Go through a puddle then pull over and look to see if there is any splash around the pod.
If none then stress less :P
If there is water all around the pod freak out
And then make a splash guard.
i think if youre driving through deep water with enough RPM to suck water into the engine, then you dont deserve to own a car.
or you should buy a 4x4 like mine
then it doesn't matter what happens :(
if you have the R tune, then it should have come with a water bypass valve. if you drive through puddles that go past the bypass valve then its a clear indication that you are in a river and its time to climb out the window.
otherwise, get the bypass valve and stop stressing.
i have the bypass. i didnt put it on as it didnt make sence
What i dont understand is how it works
if the pod gets water on it will it suck through the pod?
or splashes dont worry it, and it fully submerged it'll get air through the bypass?
if the foam sucked the water out of the air i would understand but doesnt seem to work like that
Can anyone inform me?
it will open if it cant suck enough (any?) air through the pod
but for that to happen, you probably just crashed anyway and youre in someones backyard in their pool. but the rivers are nice this time of year
it goes on the theory that it requires a certain amount of suction power (think it's measured in cuft/in) to draw water from the filter. If the foam or bypass valve has a lower restriction rate, then if the pod gets submerged...it will suck air from the bypass.
Think of it was a straw with a small hole cut out closer to the mouth piece. If you suck hard on the straw...u will be drawing in air from the inlet. but if you submerge the inlet in a glass of water...then u find that you wont be sucking in any water as air is drawn from the hole
put simply, air follows the path of least restriction
Edited by fcruz3r
would be fun if you had a white lotus esprit like james bond....or am i the only one old enough to remember that movie :(
or be an idiot like this guy>>!! i mean WTF>>> http://www.youtube.com/watch?v=nDrlWy6IAdM
but im sure you wont do anything like that.
So we all agree that unless the pod goes under water, it should be safe enough to use the intake without the real risk of waterlock??
I wont drive into any deep water!!!
But alas i do want more music gear hahaha, so someone can buy the intake! please lol
use the bypass valve as a safety measure since you already have it. But since we're nearing summer...its not an immediate problem
pics of the actual CAI will give potential buyers more confidence in the product that they will receive. Links to resellers ads arn't really that helpful....my 2 cents worth :(
Edited by fcruz3r
What is wrong with that?
Where are the air intakes on the mid engine NSX? Certainly not in the bow wave he is creating.... so I guess the only issue may be water getting into the cabin if the seals are stuffed or water getting in the exhaust if he wasn't going quick enough.
Having said that, if I did have an NSX, I certainly would not be doing that.
Edited by iamhe77
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
