i have the nismo R tune intake, which puts the pod right at the bottom where the cold air can get into it.
my worry is water lock. now i wont be driving through rivers, but puddles come up on the road and i cant do anything but drive through them. So whats the go with water lock. if 10ml of water gets in is the engine toast? or will the filter block out a fair bit and as long as i dont drive through massive deep puddles i should be ok. for reference, the pod is just above where the black grill/guards are on the front.
is it worth the risk? am i over reacting? do alot of cars have their intakes low and they have no worries?
Also, the R tune has a water lock bypass thingy, but as far as i can tell, it works if the pod is submersed and doesnt suck, it kind of opens up a to let air in and the water is therefore not sucked into the engine under extreme pressure.
What are your thoughts???
https://www.sau.com.au/forums/topic/290663-water-lock-and-cold-air-intakes/
Go through a puddle then pull over and look to see if there is any splash around the pod.
If none then stress less :P
If there is water all around the pod freak out
And then make a splash guard.
i think if youre driving through deep water with enough RPM to suck water into the engine, then you dont deserve to own a car.
or you should buy a 4x4 like mine
then it doesn't matter what happens :(
if you have the R tune, then it should have come with a water bypass valve. if you drive through puddles that go past the bypass valve then its a clear indication that you are in a river and its time to climb out the window.
otherwise, get the bypass valve and stop stressing.
i have the bypass. i didnt put it on as it didnt make sence
What i dont understand is how it works
if the pod gets water on it will it suck through the pod?
or splashes dont worry it, and it fully submerged it'll get air through the bypass?
if the foam sucked the water out of the air i would understand but doesnt seem to work like that
Can anyone inform me?
it will open if it cant suck enough (any?) air through the pod
but for that to happen, you probably just crashed anyway and youre in someones backyard in their pool. but the rivers are nice this time of year
it goes on the theory that it requires a certain amount of suction power (think it's measured in cuft/in) to draw water from the filter. If the foam or bypass valve has a lower restriction rate, then if the pod gets submerged...it will suck air from the bypass.
Think of it was a straw with a small hole cut out closer to the mouth piece. If you suck hard on the straw...u will be drawing in air from the inlet. but if you submerge the inlet in a glass of water...then u find that you wont be sucking in any water as air is drawn from the hole
put simply, air follows the path of least restriction
Edited by fcruz3r
would be fun if you had a white lotus esprit like james bond....or am i the only one old enough to remember that movie :(
or be an idiot like this guy>>!! i mean WTF>>> http://www.youtube.com/watch?v=nDrlWy6IAdM
but im sure you wont do anything like that.
So we all agree that unless the pod goes under water, it should be safe enough to use the intake without the real risk of waterlock??
I wont drive into any deep water!!!
But alas i do want more music gear hahaha, so someone can buy the intake! please lol
use the bypass valve as a safety measure since you already have it. But since we're nearing summer...its not an immediate problem
pics of the actual CAI will give potential buyers more confidence in the product that they will receive. Links to resellers ads arn't really that helpful....my 2 cents worth :(
Edited by fcruz3r
What is wrong with that?
Where are the air intakes on the mid engine NSX? Certainly not in the bow wave he is creating.... so I guess the only issue may be water getting into the cabin if the seals are stuffed or water getting in the exhaust if he wasn't going quick enough.
Having said that, if I did have an NSX, I certainly would not be doing that.
Edited by iamhe77
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
