Item: Leather R32 and R33 Gear & Handbrake boots
Condition: Brand new
Price: $55 (with express free postage to all of australia)
To Fit: (What car) Depends if your after R32 or R33 (PM me)
Contact: PM me
Comments: These are some spare sets from the last group buy. They are 100% real leather and come in black with black stitching. The metal base is bendable so it is very easy to install.
If your interested please PM me and tell me whether your after R32 or R33
Pictures (of R33) below. The R32 is made from the exact same material:
Just a warning to people out there about to buy this item... i bought 1 of this kits for a r32.. as he said the base is bendable.. WRONG i bent it the slightest bit and it snapped also the whole thing was back to front/inside out and would not fit anyway no matter what you done to it.. When i wrote to him to say what has happend all he could say was i will let my supplier know.. No refund no appoligy
Biggest waste of $55 when you can get them of ebay for $25
The new group buys are a new product and are made with a new bendable base and different material (this is because I did let the supplier know and as a result he changed the base).
I'm 99% sure I would have offered an apology to you, and if I didn't I'm sorry, but if you wanted a refund or a swap to another boot I could have organised it with you easily if you had told me so :whistling:
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
